Archive 2014 · Help with Keywords please!!
Dramodt
p.1 #1 · p.1 #1 · Help with Keywords please!!
Ok, I have over 500 shots of bike racers,
They all have number plates, and I have been adding their number into the Keywords box.
Will they get exported with the photos when I put them on a disk?
Or should I do their numbers on the photos metadata? So the race organizer can easily search for a particular rider by his number.
Thanks for any answer.
Im using Lr5.3
Screen shot,
http://eph28.smugmug.com/Other/Misc/i-bF5NRfT/0/XL/Screen%20Shot%202014-03-16%20at%208.27.35%20PM-XL.png
Mar 17, 2014 at 02:25 AM
Dramodt
p.1 #2 · p.1 #2 · Help with Keywords please!!
38 views and no help
Mar 17, 2014 at 03:47 AM
WakeTurbulence
p.1 #3 · p.1 #3 · Help with Keywords please!!
Race numbers should work fine as keywords. I shoot a lot of aviation and generally keyword the aircraft registration among other items.
I'm not sure about the burning to disc, but I know if you export for email, the default is to keep gps and keyword info with the file You have to tick the check box to strip that metadata out of the file. I would assume it would be the same burning to a disc, but why don't you try burning a few files to a blank CD and then re-import the burned files into a new folder to see if the metadata was burned properly.
-Matt
Mar 17, 2014 at 04:48 AM
Dramodt
p.1 #4 · p.1 #4 · Help with Keywords please!!
OK, hope that works! I'm working on the export now. Ugh
Thanks
Mar 17, 2014 at 05:53 AM
Ian.Dobinson
p.1 #5 · p.1 #5 · Help with Keywords please!!
your keywords should stay with the image when you export them .
Mar 17, 2014 at 07:30 AM
alohadave
p.1 #6 · p.1 #6 · Help with Keywords please!!
Unless you tell LR not to export metadata (or on the keyword itself), it will export the keywords embedded as IPTC tags in the JPEG files.
Mar 17, 2014 at 05:18 PM
Alan321
p.1 #7 · p.1 #7 · Help with Keywords please!!
When you create the new keywords Lr lets you select whether or not they can be exported. Some are essentially kept as your own private info.
Then you also get a chance to remove most of the data when actually exporting.
- Alan
Mar 18, 2014 at 02:48 AM
