Archive 2014 · downy woodpecker
Firefighterjos
p.1 #1 · p.1 #1 · downy woodpecker
Not the best shots C/C welcomed
Mar 06, 2014 at 07:59 PM
Shasoc
p.1 #2 · p.1 #2 · downy woodpecker
You did good picking your way through those branches
Unfortunately you couldn't get closer to emphasize more your subject, but you get what you can and you got some good results from the Tamron 150-600mm Enjoy the lens.
Socrate
Mar 06, 2014 at 08:11 PM
Firefighterjos
p.1 #3 · p.1 #3 · downy woodpecker
Thank you Socreate
Josh
Mar 06, 2014 at 08:23 PM
Herb Houghton
p.1 #4 · p.1 #4 · downy woodpecker
I would try to get closer next time or change the angle to avoid branches as much as possible, #2 needs a levels ( black point adjustment ) or a boost in contrast.
Mar 06, 2014 at 11:21 PM
psharvic
p.1 #5 · p.1 #5 · downy woodpecker
Even with the very longest lens you have to get very close to a small bird like a Downy. Even with a 600 you'll find you have to crop if you're much more than 20-25 feet away. Unless you have all the time and energy in the world, having birds come to you is preferable because you have better control over getting light at your back and having a good background. ( I can't emphasize how important background is for a good bird pic.) If you don't have bird feeders where you live try to find a place where Downys frequent and hang a suet feeder and maybe a small seed feeder. Set up a comfortable place from where you can wait and shoot. Of course you probably won't want a picture with the feeder but you'll find that they often land nearby at the same spot before feeding. Hope this helps a bit and good luck.
Mar 06, 2014 at 11:56 PM
Ted ellis
p.1 #6 · p.1 #6 · downy woodpecker
Having been there and having done that, listen and apply the suggestions. You will only get better. TFS.
Ted
Mar 07, 2014 at 01:47 AM
Firefighterjos
p.1 #7 · p.1 #7 · downy woodpecker
Yea very heavy wooded area next time ill try to get closer.... Thanks for all info..
These guys hang around here every day ill try tomorrow.
Josh
Mar 07, 2014 at 03:43 AM
