TooManyShots Offline Upload & Sell: Off
I think the D7000 and D7100 buffer size is the same. So, regardless what cards you use, the most you can get is 14 shots before the buffer filled up (with 12bit, no NR, no Auto distortion, and compressed raw). Most people can get about 10 to 11 with 14bit, lossless raw compression, and with NR. BTW, with auto distortion enabled, it takes up a lot of memory space on each RAW shot. With it enable, I get about 8 shots. With it disabled, I can about 10. Also, the ISO settings do not affect the buffer size at all.
