       2       3       end
Archive 2014 · What the heck is this?
grog13
p.1 #1 · p.1 #1 · What the heck is this?
I was shooting this morning and when I downloaded was greeted with these two beauties. Frames before & after were fine. Shooting on tripod (60D with 10-22) in live view, aperture priority, f/11, shutter speeds 2-5 seconds (using 6 stops ND) with long exp NR enabled. Are these dark frames gone wrong or what??
Mar 01, 2014 at 10:03 PM
onegreatcity
p.1 #2 · p.1 #2 · What the heck is this?
Memory card error/failure is my guess. Did you use a card reader?
Mar 01, 2014 at 10:10 PM
Monito
p.1 #3 · p.1 #3 · What the heck is this?
You inadvertently opened the card door slightly and some frames got light-struck.
Mar 01, 2014 at 10:28 PM
AnthonyRay
p.1 #4 · p.1 #4 · What the heck is this?
Yes, certainly is the card.
I actually had this happen to me a LOT back when SD cards were new. The last time it happened was using my 60D, and oddly enough, it only happened to the RAW files (looked exactly like this). The thumbnails would show correctly, but the file itself was corrupted. Didn't matter how it was read - the file was bad on the card.
Make sure that you're using a good and fast class 10 card - decent brand. Put this particular card on the "watch list".
I've used the same card I had the issues with on the 60D since then, and had no issues.
I've never once had this happen to me with a CF card.
Mar 01, 2014 at 10:35 PM
Shutterbug2006
p.1 #5 · p.1 #5 · What the heck is this?
Defective memory card, or it needs a fresh low and high level format.
Mar 02, 2014 at 01:03 AM
grog13
p.1 #6 · p.1 #6 · What the heck is this?
Thanks for the info. Makes me think twice about the value of dual card slots. I've never had a card problem before, and figured they were one of the more reliable parts of the system. This particular card was a Sandisk 16mb SDHC1. I've always bought Sandisk and never had a problem - what are other folks' favorites?
Mar 02, 2014 at 01:22 AM
gpop
p.1 #7 · p.1 #7 · What the heck is this?
any(every) time I've had files end up like that it's been the card reader.
Mar 02, 2014 at 01:30 AM
Roy Morales
p.1 #8 · p.1 #8 · What the heck is this?
I had a cheap USB card reader do that . I was downloading from a firewire and another card using USB [ not sure if USB 1 or 2 ] Put the card in firewire - everything OK - tossed the USB reader .
Mar 02, 2014 at 01:50 AM
skibum5
p.1 #9 · p.1 #9 · What the heck is this?
pobably the card read or the card, maybe something failing in the camera or HD
Mar 02, 2014 at 01:56 AM
Jonathan Huynh
p.1 #10 · p.1 #10 · What the heck is this?
Memory card error.
Mar 02, 2014 at 02:03 AM
BrianO
p.1 #11 · p.1 #11 · What the heck is this?
Now that was funny.
(Especially since back in the film days it happened to me once or twice.)
Mar 02, 2014 at 02:09 AM
BrianO
p.1 #12 · p.1 #12 · What the heck is this?
grog13 wrote:
...when I downloaded was greeted with these two beauties.
Did you download via camera cable, WiFi, or pulled the card and used a card reader?
Mar 02, 2014 at 02:11 AM
grog13
p.1 #13 · p.1 #13 · What the heck is this?
Used the computer's onboard card reader.
Mar 02, 2014 at 02:22 AM
BrianO
p.1 #14 · p.1 #14 · What the heck is this?
The most likely suspect, as mentioned above, is the card reader, followed by the card.
If you put the card back in the camera and try to download the file via cable, and the file still looks scrambled, then that'll indicate either a card problem or, less likely, a camera problem.
If a cable download has no problems, then it's almost certainly the card reader.
Mar 02, 2014 at 03:50 AM
PhotoTeacher
p.1 #15 · p.1 #15 · What the heck is this?
Do the frames show up OK on the camera's LCD screen? If so, then it is probably a card reader problem. If the frames look the same in-camera, then probably the card is bad.
Mar 02, 2014 at 05:38 PM
Monito
p.1 #16 · p.1 #16 · What the heck is this?
As I understand it, the images on the camera's LCD are the embedded JPEGs which can look OK, even if the Raw is corrupted, so that is not a definitive test. I refer you to BrianO's post #14 just above.
Mar 02, 2014 at 06:50 PM
ebiggs
p.1 #17 · p.1 #17 · What the heck is this?
I also think it is the card. But I suggest you get a brand new high quality card and not trust that one anymore.
Don't buy cheap memory cars, ever.
Mar 02, 2014 at 09:52 PM
EOS20
p.1 #18 · p.1 #18 · What the heck is this?
Because they'll end up driving you crazy!
Mar 02, 2014 at 09:57 PM
ebiggs
p.1 #19 · p.1 #19 · What the heck is this?
And in my case it is a very shot drive!
Mar 02, 2014 at 10:53 PM
digitalbug30d
p.1 #20 · p.1 #20 · What the heck is this?
Shhh there are women and Nikon photogs they might believe that..
Edited on Mar 03, 2014 at 03:26 AM · View previous versions
       2       3       end
       2       3       end
