adnan76 Offline Upload & Sell: On
Hi,
Which adapter is necessary to use the Metz flashes on a Sony A7r?
Thanks!
Minomaniac wrote:
+1 on the Metz ones.
The Metz 58-AF2 has an auto mode via a photo diode in the flash.
In that mode the flash doesn't fire a pre-flash and therefore has much lesser delay than TTL. Helps avoid sleepy eye effect too.
It can even be used as a ratio controller for the Sony flash system . Works pretty good on the A7r, albeit it feels some kind of big on the small camera.
Keep in mind, that Metz uses the old Minolta hot shoe on all of their flashes, so you need the Sony adapter.
Edit: TTL/HSS is supported too. The firmware can be updated via USB....Show more →
