Archive 2014 · MA Adjustments w/TCs
cameron12x
p.1 #1 · p.1 #1 · MA Adjustments w/TCs
Is this required for TCs?
Or put another way, say for example you've MA'ed your 400mm lens to your camera body. Will there be any benefit of performing the micro-adjustment again if you mount a 1.4X TC with the same lens?
Just curious.
Jan 23, 2014 at 11:24 PM
Peter Figen
p.1 #2 · p.1 #2 · MA Adjustments w/TCs
Yes, it makes a real difference and the cameras remember your lens+converter combos as well.
Jan 23, 2014 at 11:30 PM
stanj
p.1 #3 · p.1 #3 · MA Adjustments w/TCs
It's as required as doing MAs in the first place. Some people don't bother (or don't have cameras that allow it), others can't live without. Since MA with TC is completely separate from without TC, you should do both.
Jan 23, 2014 at 11:33 PM
arbitrage
p.1 #4 · p.1 #4 · MA Adjustments w/TCs
YES, YES, YES.... a lot of my lenses require almost zero MA as a native lens but as I add on my 1.4 and then 2.0TC, the MA value gets worse with each usually. You definitely want to MA with each combo. The camera will register the TC and remember them. The newest cameras even support different SNs for multiple TCs (as some have 2 copies of a 1.4TC).
Jan 23, 2014 at 11:42 PM
dgdg
p.1 #5 · p.1 #5 · MA Adjustments w/TCs
I double Geoff's Yes's
My experience is the same.
Yes yes yes yes yes yes!!!
David
Jan 24, 2014 at 12:31 AM
docsmiles17
p.1 #6 · p.1 #6 · MA Adjustments w/TCs
^^^^^^^THIS^^^^^^^^^
Jan 24, 2014 at 12:36 AM
Bmetcan
p.1 #7 · p.1 #7 · MA Adjustments w/TCs
Yes. And I'll add another question I've personally wondered about regarding this subject. Do people MA to a wide open TC (ie f5.6 on a f4) or stop down a bit?
Jan 24, 2014 at 01:08 AM
docsmiles17
p.1 #8 · p.1 #8 · MA Adjustments w/TCs
Here is a thread on Dot-tune method....should answer any questions you have.
https://www.fredmiranda.com/forum/topic/1187247
Jan 24, 2014 at 01:15 AM
kmunroe
p.1 #9 · p.1 #9 · MA Adjustments w/TCs
i try to shoot my 600mm with or without the 1.4 in the 7.1 range so thats what i did my MAs at.. so now if it's open a little, or closed a little it still shoots great
Jan 24, 2014 at 05:32 AM
arbitrage
p.1 #10 · p.1 #10 · MA Adjustments w/TCs
Usually it is always recommended to do it wide open because the software needs as narrow of a DOF as it can get to actually see a difference. However, if you always shoot at a particular aperture then MAs at that f-stop may be best but as you stop down, MA becomes less critical because of the DOF....this also applies to shooting at greater distances....the DOF increases and MA becomes less important.
Also if you shoot in AI Servo mostly....MA makes almost no impact as the servo drive steps are often more variable than any normal type of MA adjustment.
Jan 24, 2014 at 08:35 AM
p.1 #11 · p.1 #11 · MA Adjustments w/TCs
I do my AFMA tests with the lens wide open. I also test/adjust all likely Extender combinations.
Jan 24, 2014 at 08:50 AM
Andrew J
p.1 #12 · p.1 #12 · MA Adjustments w/TCs
Many long lenses have focus shift. My 500/f4L moved 5 points when stopped down 2/3 of a stop and so does my 600/f4L. So I always test wide open and stopped down. BTW, focus shift is why so many are unhappy wth LensAlign which must be done wide open.
Jan 24, 2014 at 11:30 AM
dgdg
p.1 #13 · p.1 #13 · MA Adjustments w/TCs
I never realized this with the 600mm. I would suppose if you are smack in the middle of your dof at f4, then five points off stopped down may not matter that much? Guess it is worth knowing at least so you can make a conscious decision about it. My images seemed sharp enough stopped down, so I never bothered to check. I am usually wide open anyway to favor shutter speed and iso.
David
Jan 24, 2014 at 12:44 PM
