Ian.Dobinson Offline Upload & Sell: Off
Ok , the easiest way I've found of getting LR to know about a drive is to import something to that drive .
So I just import 1 image into LR , and in the import dialogue I choose the new destination and create a folder name - in your case this could be LR MASTER FOLDER
Once that's done you can remove the imported image and the folder is still there as far as LR is concerned .
It's then a case of drag the folders (in LR) to this MASTER FOLDER .
Personally I'd say your whole set of raw images on an SSD is overkill . I very much doubt you'd see any day to day benefit . You may see (probably will) see faster imports and exports etc , but that's probably it
Enjoy
