Alan321 Online Upload & Sell: Off
You could try photographing them with your DSLR camera. Less convenient to do but it saves on cost of a new scanner and also on storage space when you're not scanning. Depending on when you do it you might get away with ambient lighting and perhaps adding a white reflector so that you need not buy speedlites or other dedicated lighting. Use a small enough aperture and even bends in the prints will not cause significant focus errors. Use a tripod and any shutter speed will be ok, so that you can stick with low ISO for best noise and DR performance.
As you are dealing with printed photos instead of film you can get away with using anything from 200-600ppi equivalent. i.e. Certainly no need for 2000ppi or more for this application.
The biggest downside of dealing with prints instead of film is that any blown highlights or lost shadows are already locked in forever, but you can still manipulate the contrast and so on to add a bit of life to the new versions that you create.
I believe that it is best to use colour mode rather than B&W even for B&W photos.
- Alan
