Archive 2014 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II an...
luke0622
p.1 #1 · p.1 #1 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
Thinking about getting the AquaTech Soft Collapsing traveling lens hood for my 400/2.8 AF-S II and 600/4vr.
Any Nikon shooters using that on the same lenses? Any advices and pictures with the hood on the lens? I've heard it's not as long as the Nikon 2-piece hood.
Any input and photos will be appreciate it.
Thanks, y'all.
Jan 08, 2014 at 08:00 PM
tdong
p.1 #2 · p.1 #2 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
i have it but never get to use it. did try to mount it on my 500. should works as advertise. The reason i bought it was because my hood screw was broken on the last trip
Jan 08, 2014 at 08:07 PM
luke0622
p.1 #3 · p.1 #3 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
Thanks, tdong.
I'd love to see a photo with that on the lens.
Jan 08, 2014 at 08:19 PM
tdong
p.1 #4 · p.1 #4 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
ok will take a shot for you tonight
Jan 08, 2014 at 08:28 PM
luke0622
p.1 #5 · p.1 #5 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
Thanks
Jan 08, 2014 at 08:53 PM
sjms
p.1 #6 · p.1 #6 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
I use it on my 300 semi irregularly.
Jan 08, 2014 at 08:55 PM
luke0622
p.1 #7 · p.1 #7 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
how do you like it, sjms? 300 is not really an issue for me, just the 400 and 600 with 2-piece hood when packing, it's too wide (tall); just looking for an alternative way to travel with those lenses.
Jan 09, 2014 at 05:57 AM
sjms
p.1 #8 · p.1 #8 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
once initially adjusted it wraps on easily.
ungainly looking but functions as it should
in the years I have had it the hood has probably saved me at minimum 1 replacement.
takes a beating.
your choice of roll up or flat as needed for travel
actually protects things it wrapped around in transit.
  X20    14mm    f/2.5    1/90s    3200 ISO    0.0 EV
Jan 09, 2014 at 03:29 PM
cebseb
p.1 #9 · p.1 #9 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
I have it and used it quite a bit when I had both my 400mm 2.8 VR and 600mm f4 VR. I needed it since the hoods were just too fragile to pack and travel with on flights. Putting it on was a bit cumbersome for the first few times, but then got much easier than the two piece hoods. Most definitely worth the price.
Jan 09, 2014 at 03:31 PM
luke0622
p.1 #10 · p.1 #10 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
takes a beating.
Thank you, I really appreciate the photo.
Jan 09, 2014 at 05:12 PM
luke0622
p.1 #11 · p.1 #11 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
Thanks for the feedback, I am looking forward to get one for my lenses.
Thanks again
Jan 09, 2014 at 05:15 PM
Hardcore
p.1 #12 · p.1 #12 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
Can you remove the foot and slide the hoods over the lens closer to the mount?
Jan 09, 2014 at 05:47 PM
sjms
p.1 #13 · p.1 #13 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
I don't quite get the question.
Jan 10, 2014 at 04:46 AM
tdong
p.1 #14 · p.1 #14 · AquaTech Soft Collapsing lens hood for 400/2.8 AF-S II and 600VR
sorry was too busy
very strong you can even stand it
Jan 11, 2014 at 12:16 AM
