justruss Offline Upload & Sell: Off
I don't see any reason why running an HDD at 0 F ambient would matter. Most electronics run more efficiently when cool.
In fact, last-ditch efforts to save a failing HDD-- in order to copy off any data-- includes putting the HDD in the freezer for a few hours before rushing to get it to spin-up and make the transfer.
As others have mentioned, the biggest issue is potential condensation. If you run a 0 F HDD at 70 F ambient, you may well get droplets of water forming, which could short something out or corrode wiring over time. Same as we worry about with cameras. But, again, this is mostly an over-thought issue... many photographers get condensation dozens of times without any negative long-term impact. But it's a risk.
In any case, sounds like the OP is well in the clear by now!
