ZoneV Offline Upload & Sell: Off
I need to update my computer, for the Windows update to 7 or 8.1 I want to make the step to a 64bit system. Which results in some new software. But this is most likely not much fun, but much work.
I hope the new system will work much faster - and I will like the new Photoshop and Lightroom, and all the NIK filters :-)
I think I have enough lenses and enough cameras.
I need to use the gear I have!
Some cheap lenses I will likely buy, but those are things I do not plan, but find it on fleemarkets or Ebay.
It would be good to make a big update of my website, but this will probably not happen. Donīt like such work, and there is no real need for it.
One bigger photographic change seems to be likely: Working with film again.
I have some ideas I should test with 6x6 or 6x9cm film. Probably even bigger.
For this I need to find a good cheap way to get the negatives / slides to digital files, most likely with a DSLR and macro or enlarger lens for the first tests.
A simple test need to be done with 135 film, there I even have a scanner.
