Archive 2013 · 7 Ft Parabolic
p.1 #1 · p.1 #1 · 7 Ft Parabolic
Will the subject umbrella and a single SB-800 be adequate coverage for small family group illumination
Dec 20, 2013 at 03:22 PM
hondageek
p.1 #2 · p.1 #2 · 7 Ft Parabolic
Is the Para silver? If you can arrange the family so they are on roughly the same focal plane you'll be able to use a larger aperture. Combine that with a high-ish ISO and you should be fine.
Dec 20, 2013 at 03:36 PM
p.1 #3 · p.1 #3 · 7 Ft Parabolic
Yes, The liner is silver. Thanks for your quick response.
Dec 20, 2013 at 04:43 PM
cwebster
p.1 #4 · p.1 #4 · 7 Ft Parabolic
A 7ft para with one speedlight... really. Maybe with a high enough ISO, but it would not be my choice. I'd rent something or look for a stronger portable strobe.
<Chas>
Dec 21, 2013 at 02:24 AM
Gregg Heckler
p.1 #5 · p.1 #5 · 7 Ft Parabolic
As Chas mentions, you'll need to increase you ISO and maybe drag the shutter a bit.
Dec 21, 2013 at 04:33 PM
hondageek
p.1 #6 · p.1 #6 · 7 Ft Parabolic
Dragging the shutter won't affect flash output.
Dec 21, 2013 at 09:34 PM
Waki
p.1 #7 · p.1 #7 · 7 Ft Parabolic
I've used one flash in a few 7 ft umbrellas. I have a couple other larger flash options Ike a Profoto 600R, an Einstein and VML and am on the list for a B1 but some times you just don't have the time to set up or have that stuff with. Keep the umbrella close to the subject, shoot on higher power and if possible try shooting through if you have one that's translucent. You can get it even closer without sticking your talent with the umbrella shaft. I think the 7 ft translucent is a great product. I use it outside as a scrim, a diffuser for shooting thru. If you can find one one more flash unit, borrow or buy, it obviously works better.
Go for it though. It's how we learn.
Dec 22, 2013 at 02:20 PM
JohnBrose
p.1 #8 · p.1 #8 · 7 Ft Parabolic
Should work fine, just watch shadows on subjects and background. It also depends a bit on size of room and size of family group, but you don't need a ton of equipment to get great results, you just need to know what you are doing.
Dec 22, 2013 at 02:57 PM
Gregg Heckler
p.1 #9 · p.1 #9 · 7 Ft Parabolic
Dragging the shutter won't help the exposure but it will the ambient and open up the shadows. I think it makes for a nicer shot like this when you only have one light source.
Dec 22, 2013 at 09:26 PM
