LightShow Offline Upload & Sell: Off
johnahill wrote:
I've got an oly 35mm shift that I'm trying to use on Fuji X-E1.
I'm on my second adapter now and both don't align properly when the lens is rotated and locked onto the adapter.
What I mean by that is the alignment dot on the oly lens doesn't align with the alignment dot on the x mount side of the adaptor.
This would not be a problem on most lenses but with the shift lens it means the shift movement is out of whack and not parallel with the camera so shifting left and right results in a slight diagonal shift movement.
This is the same on a cheap ebay adapter and my just arrived today fotodiox adapter.
If anyone has the Kipon adapter could you please check to see if this is any better.
Unfortunately metabones don't make an oly-x mount adapter, so the next step up would mean a very expensive novoflex
...Show more →
Was the seller Fotodiox? I'd talk to him about it, he's great to deal with, he will probably check to see if they will all be like that, then make a design change.
You could also try big_is adapters on eBay, ask him if his have the same problem.
