BigIronCruiser Offline Upload & Sell: Off
Sekonic sells meters that trigger PW's, and Paul Buff sells a Cyber Commander (CC) that will trigger his CSRB receivers. The PW solution is more expensive, but offers TTL plus an option (AC3 Zone Controller) that lets you remotely adjust the power of your speedlights. The Cyber Commander has a built-in meter that's been quite accurate in my experience. Bottom line is that the PW is more elegant, but requires a meter, transmitter and receiver. The Buff gear, on the other hand, is less expensive and obviates the need for a separate meter, but does not support TTL or remote power adjustments for your Canon flash.
If you're going with PW:
1. Sekonic meter with built-in PW trigger
2. FlexTT5 for each speedlight
3. MiniTT1 for the camera hotshoe
4. AC3 Zone Controller
If you're going with Buff products
1. CyberCommander (CC)
2. CSRB and cable for each speedlight
3. CST for the camera hotshoe (The CC can sit in the hotshoe to trigger the remote flash unit(s), although most people seem to prefer the CST as the triggering device while keeping the CC in their hands as a meter.)
