Eyeball Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · Presentation at wedding on screen, need help | |
Assuming you have a laptop, is it with Mac or Windows?
If you have Powerpoint, you can certainly use it, but if the situation is as simple as you say then there are many alternatives including free ones.
If you have the right cable/interface with the venue's projector, you might even be able to do it with a tablet or smart phone.
I recommend you first pin down the interface the venue needs (VGA, DVI, HDMI, etc.), then decide which of your devices will support that, and then think about the software (which will likely be the easiest part).
You may even want to double-check with the venue to see if they have multi-media equipment that they can use in addition to the projector. Then you could just give them a Jpeg on a USB and let them handle it. The reason I mention this is that you will probably have enough on your mind shooting the wedding and then doing a quick cull and arrangement of the requested composite (especially if you will be doing everything yourself). Being able to not worry about the mechanics of the projection could be a benefit, particularly since you will be shooting the very important father-daughter dance.
