xdmg Offline Upload & Sell: Off
p.1 #1 · p.1 #1 · Switching to Nikon.. Could use advice on lighting kit. | |
In the middle of switching from Canon to Nikon so starting fresh lighting wise...
Looking for best bang for the buck but I will spend extra if its worth it.
Primarily a event photographer.. this is what I am looking for
-TTL flash that will typically be used on camera only. Thinking SB900/SB910, are there any 3rd parties that are comparable? I want the highest power/recycle times.
-Trigger multiple off camera flashes with the option to use the ETTL flash ON camera as a fill.
-Radio trigger is obviously preferred because this setup would be used to light a wedding reception, etc.
-Adjust power/settings of the off camera flashes wirelessly.
-The actual flashes used off camera do not need to have TTL.
Thanks!
