Archive 2013 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
Admin
p.1 #1 · p.1 #1 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
B&H Photo has received the first shipment of the new Sigma 24-105mm F/4 DG OS.
This lens features optical stabilization and is compatible with Sigma's USB dock. You may purchase it today for $899.
(Currently only the Canon mount is available)
Sigma 24-105mm F/4 DG OS HSM Lens ($899)
Here are the main features and specifications:
  • Lens Construction: 19 elements in 14 groups
  • Dimensions (Diameter x Length): 3.5in x 4.3in
  • Weight: 885g / 31.2oz
  • Minimum focusing distance: 45cm /17.7in
  • OS (Optical Stabilizer) functionality
  • Filter size: 82mm
  • Maximum magnification ratio: 1:4.6
  • Angle of view (35mm equivalent): 84.1°-23.3°
  • HSM delivers high AF speed and quiet performance
  • Offers F/4 brightness throughout the zoom range
  • Super Multi-Layer Coating reduces flare and ghosting
  • Rounded 9-blade diaphragm
  • Mount conversion service available
  • Sigma USB Dock compatible
Dec 03, 2013 at 07:04 PM
Sandeep Singh
p.1 #2 · p.1 #2 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
Good Specs. I am an amateur only but I still dont like zoom out lenses. I mean front barrel extends out. Doesnt seem to be weather proof.
Dec 03, 2013 at 07:29 PM
YonathanZ
p.1 #3 · p.1 #3 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
I know some L lenses, including the Canon 24-105, have extending front thingies. Aren't L lenses weather sealed to some extent?
Dec 04, 2013 at 07:25 AM
gregfountain
p.1 #4 · p.1 #4 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
. This just cracked me up Yes, the barrel of Canon’s 24-104 (and the 24-70 as well) extend from the lens as you zoom, and this is typical for shorter to mid range zooms. Most L-series lenses have a rubber dust gasket at the mount, but I would’t call them “weather-proof.”
Dec 04, 2013 at 07:44 PM
jojomon11
p.1 #5 · p.1 #5 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
No love for this lens?
Dec 05, 2013 at 02:41 AM
johnctharp
p.1 #6 · p.1 #6 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
For the Canon mount?
Not really. It'll have to prove to be an outstanding lens- not just a good lens- to attract EF-mount users. F-mount users will likely find it highly desirable.
Dec 05, 2013 at 02:44 AM
dfresh
p.1 #7 · p.1 #7 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
If it were $300 cheaper perhaps Canon 24-105s are dirt cheap nowadays.
Dec 05, 2013 at 09:48 PM
asiafish
p.1 #8 · p.1 #8 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
Why go third party when the Canon lens is so well respected and only slightly more expensive at retail and cheaper used or white box from a kit.
Dec 05, 2013 at 10:24 PM
johnctharp
p.1 #9 · p.1 #9 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
The answer to that question is what we're waiting to find out .
Dec 05, 2013 at 11:00 PM
Erik_J
p.1 #10 · p.1 #10 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
If it have better IQ of course. We don't know yet. It's not like the Canon version is so fantastic that it can't be improved
Dec 05, 2013 at 11:11 PM
asiafish
p.1 #11 · p.1 #11 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
Nothing is so fantastic that it can't be improved. Leica's 50mm Summicron was described for decades as "Perfect" (by Leica and others), but sure enough, they improved it.
Show me a better zoom in the 24-105L's range and speed? The 24-70 f/2.8 class are mostly better, but those are twice the price and much heavier. Nikon's 24-120 f/4 has its fans, and better range, but I wouldn't say its IQ is better and its build is actually a notch below.
The Sigma may be great, but it would have to be really superb to trump the Canon, which is also a great lens for what it is.
Dec 12, 2013 at 12:44 AM
johnctharp
p.1 #12 · p.1 #12 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
Reviewed by Bryan at TDP
It looks like a great standard zoom, well up to specs with the Canon and probably the best in class on other mounts!
Dec 15, 2013 at 03:00 AM
EB-1
p.1 #13 · p.1 #13 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
It's still in stock for Canon EF and has been continuously unless I missed a day. I don't think the lens is very popular. Perhaps it will be cheaper later on.
Dec 15, 2013 at 03:24 AM
alexdi
p.1 #14 · p.1 #14 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
The real benefit of this lens is buried in the test charts. It's light transmission. DxOMark measured T/5.1 with the 24-105/L and T/4.2 with this Sigma. Couple that with better edge performance and there's not much reason to prefer to the L if you're buying new.
Dec 16, 2013 at 07:26 PM
johnctharp
p.1 #15 · p.1 #15 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
The new Sigma is sharper across the frame than the L, and is at least half a stop faster, while matching the Canon on CA and trading distortion results, falling behind only in vignetting (but again, it's faster).
I'd like to try one out some time .
Dec 16, 2013 at 09:31 PM
photorebel
p.1 #16 · p.1 #16 · Sigma 24-105mm F/4 DG OS HSM Lens in Stock! ($899)
Unless you can get the L in a kit, or buy the kit lens. The current 6D/5DIII kits put the effective price of the lens at $650 or so.
If I were buying straight out..I'd look at Sigma's $899.00 vs Canon's $1199.00 price however.
Dec 16, 2013 at 09:39 PM
