philber Offline Upload & Sell: Off
p.1 #6 · p.1 #6 · Nikon D800e Vs Sony a7r Vs Canon 5D Mark III | |
Orlov, when I read your piece, I see a lot of theory. A7R and the 2 DLSRs are so different you should be able to make up your mind without undue stress. Either you are taken with the small size ans low weight, or forget the A7R. But if the idea of having your camera with you at all times inspires you, forget the DSLRs. It is that simple.
Supposing the Sony is not your cup of tea, either you go for tilt-shift lenses and LiveView, and that means Canon, or you go for resolution and DR, and that is Nikon.
Except of course that you can use Canon Tilt-shift on the Sony A7R..
Just kidding... Seriously, why don't you rent each one for a couple of days, and see with which one you connect. That will tell you more and one thousand opinions.
