Archive 2013 · Sekonic/Pocket Wizard Question
mallen2
p.1 #1 · p.1 #1 · Sekonic/Pocket Wizard Question
Just got a set of PW's Plus II Transceivers and a Sekonic 358 Light Meter.
PW's work fine, but when i try to fire them using the meter, nothing happens.
The chip in the back says: Sekonics RT Module-32.
I have the meter set to wireless mode & on Channel 1.
Usually when i have a problem like this it's usually me, but i cant figure it out.
Like i said the PW's work fine on the camera, and off as a remote fire, but the ole meter doesn't want to cooperate, Wondered if the chip was bad?
Would appreciate some help.
PW's are in a AB 1600.
regards,
Mike Allen
Brunswick, Ga.
Nov 25, 2013 at 08:58 PM
hondageek
p.1 #2 · p.1 #2 · Sekonic/Pocket Wizard Question
Make sure the 358 has a relatively fresh battery. Don't rely on the battery indicator on the meter.
Nov 25, 2013 at 10:48 PM
Mark_L
p.1 #3 · p.1 #3 · Sekonic/Pocket Wizard Question
When I first got the module I thought I had it set to chnl1 not realising you need to click the wheel over one more so the screen moves off the channel selection screen to use it.
Nov 25, 2013 at 11:10 PM
mallen2
p.1 #4 · p.1 #4 · Sekonic/Pocket Wizard Question
Mark,
Thanks Man!
That's exactly what it was, everything is working fine now.
Appreciate the help!
Regards,
Mike Allen
Nov 25, 2013 at 11:39 PM
Mark_L
p.1 #5 · p.1 #5 · Sekonic/Pocket Wizard Question
I'm glad it isn't just me that got confused with it, it drove me nuts until I figured that out!
Nov 26, 2013 at 01:17 PM
mallen2
p.1 #6 · p.1 #6 · Sekonic/Pocket Wizard Question
Thanks Again!.........................M
Nov 26, 2013 at 09:11 PM
Michael White
p.1 #7 · p.1 #7 · Sekonic/Pocket Wizard Question
You'll need a different chip for the flexes. Your chip only works with non ctl radios. unless you make the flexes use standard channels and then you lose the ettl info'
Nov 28, 2013 at 07:55 AM
mallen2
p.1 #8 · p.1 #8 · Sekonic/Pocket Wizard Question
I don't understand what you are saying, it seems to be working now..........Mike A.
Nov 28, 2013 at 12:09 PM
Mark_L
p.1 #9 · p.1 #9 · Sekonic/Pocket Wizard Question
He's using Plus II's?
Nov 28, 2013 at 02:06 PM
mallen2
p.1 #10 · p.1 #10 · Sekonic/Pocket Wizard Question
I'm using a sekonic L-358 meter with a pair of Pocket Wizards Plus II Transceivers.
Have i missed something?
.Mike
Nov 28, 2013 at 02:20 PM
