Archive 2013 · Curious - anyone use this?
Bob Jarman
p.1 #1 · p.1 #1 · Curious - anyone use this?
A dll got clobbered so I had to download and re-install the NikCollection, AKA CEPro4, SEPro2, etc.. Added to this was Analog Efex Pro, new to me.
Sample image using wet plate texture, bokeh slider, and dust/scratch/ template. A gimmick but certainly has specific uses...easier than hand building in CS
Bob
Nov 02, 2013 at 12:14 AM
RustyBug
p.1 #2 · p.1 #2 · Curious - anyone use this?
Apparently just released according to some other threads in other FM forums.
Nov 02, 2013 at 12:45 AM
Bob Jarman
p.1 #3 · p.1 #3 · Curious - anyone use this?
Thanks,
Fortuitous timing I suppose...
Bob
Nov 02, 2013 at 12:56 AM
Oregon Gal
p.1 #4 · p.1 #4 · Curious - anyone use this?
No I have not used it but did hear about it through the forum like Kent stated above. I can't give an opinion one way or the other since I have no experience using it.
Nov 02, 2013 at 05:21 AM
dmacmillan
p.1 #5 · p.1 #5 · Curious - anyone use this?
I've only done a quick run through to make sure it was working. Here's my first impressions:
It has potential, but default settings on just about everything are too strong. That's OK because you can adjust to taste. I work hard to remove dust and scratches when scanning in my film negatives, I can't imagine using the dust and scratch filter. To me it seems silly. I also use software to remove clicks and pops when digitizing my 78s and LPs. I can't imagine taking a digital source, like a CD, whose big advantage is noise free playback, and artificially introducing noise.
I was interested because I've been thinking about buying Replichrome because I like the look. I thought Analog would give me a similar look. It sort of does, but the settings are not nearly as robust. I'll probably get Replichrome after all.
It's a great free upgrade, but I doubt I would have gotten it if I had to pay.
Nov 02, 2013 at 12:14 PM
