hugowolf Offline Upload & Sell: Off
CRFTony wrote:
Robert & Brian - To update, this morning I did some new prints via Lightroom. I changed the printer settings and unchecked "Speed" (it mentioned that it allows printing in both directions) and checked the "Fine Detail" setting. I'm seeing a dramatic difference for the better! I printed everything at 2880. Next time around, I might try the 1440 but I'm very, very pleased with these prints now. I haven't tried any wallets yet but I can see a difference in the larger sizes already.
So things are moving in the right direction.
If the print head is aligned, bidirectional printing should produce identical results to unidirectional.
Setting ‘finest detail’, will produce no better prints than without it set, unless you are working with vector files, and it slows down printing. But has to be set if you want to input at 720 ppi. Why you would want to input at 720 ppi is another unanswered question.
And unless you are printing on a high gloss surface, 2880 will be marginally worse than 1440 dpi.
Nothing you have mentioned should have changed the print quality in any substantial way. So if “things are moving in the right direction”, it is accidental.
Brian A
