Archive 2013 · WFT-E6A and Canon 1D X
Joshua J. Ahern
p.1 #1 · p.1 #1 · WFT-E6A and Canon 1D X
Hi there
do you know a video tutorial (on Youtube or else) that shows how to set-up
a combo WFT-E6A transmitter/1D X/Eos Utility ?
or any pdf files? short one if possible.
I want to be able to shoot with 1D X with the transmitter
downloading the pictures to my computer.
There's a pdf from Canon, but it contains more than 100 pages of settings
for different set-ups; a little hard to find our way with it.
thank you
Jean-Yves
Oct 30, 2013 at 10:45 PM
doogie2304
p.1 #2 · p.1 #2 · WFT-E6A and Canon 1D X
http://www.shuttersnitch.com/forums/viewtopic.php?f=4&t=1495
hope this helps. (make sure you read his second post)
edit: just realised you want to go to a computer, not am ipad, but it may still help you.
otherwise, https://www.google.com.au/search?q=set+up+wft-e6a+and+1dx&oq=set+up+wft-e6a+and+1dx&aqs=chrome..69i57.14060j0j7&sourceid=chrome&espvd=215&es_sm=122&ie=UTF-8
Oct 30, 2013 at 10:49 PM
Joshua J. Ahern
p.1 #3 · p.1 #3 · WFT-E6A and Canon 1D X
sounds great doogle
thank you
Oct 30, 2013 at 11:35 PM
Joshua J. Ahern
p.1 #4 · p.1 #4 · WFT-E6A and Canon 1D X
I finally got through it. After 7-8 hours...
WFT-E6A works pretty good with the 1D X
But you need to install the last version of EOS Utility (if using it with the Canon transmitter)
which is V 2.13.25 (updater)
You can download it here:
EOS Utility v 2.13.25 (updater)
As for informations for the different kind of connections,
you will find all you need here;
Wireless File Transmitter Setup Guides
Nov 02, 2013 at 06:56 PM
Sizeman
p.1 #5 · p.1 #5 · WFT-E6A and Canon 1D X
I have used CamRanger. costs less than half and set up took about 3 minutes to do and have pictures transmitted to my iPad or iphone
www.camranger.com
Nov 04, 2013 at 08:17 PM
Joshua J. Ahern
p.1 #6 · p.1 #6 · WFT-E6A and Canon 1D X
I've been working with the CamRanger but
the CamRanger quits during the shootings cause I was using
a high burst rate (with a Canon 1 D X ) and the CamRanger wasn't able to handle it.
CamRanger was quitting unexpectedly.
But it was the only issue I've experienced with the CanRanger so far.
(I have to transfer to a MacBook raw 18MP images.
which means big files in a short amount of time.)
that's why I went with the Canon WFT/E6A.
Nov 05, 2013 at 05:22 AM
