Archive 2013 · dumb question - af/mf switch
newtophoto
p.1 #1 · p.1 #1 · dumb question - af/mf switch
What is the point of this switch on the body and lens? Can't you just leave it in AF, and then move the ring manually when you want to focus manually?
Oct 21, 2013 at 09:03 PM
trenchmonkey
p.1 #2 · p.1 #2 · dumb question - af/mf switch
If the lens you're using has MF override, then yes. But then you'll need to rear button focus or your
shutter button 1/2 depress will throw your MF "adjustment" OOF The switch solves THAT problem.
Oct 21, 2013 at 09:09 PM
p.1 #3 · p.1 #3 · dumb question - af/mf switch
You can do this with a lens that has a "real time manual focus" AF motor, but not with lenses with other types of AF, where you can end up fighting against the AF motor. Additionally, with some cameras, you might always have AF associated with the shutter button. Imagine how torqued you'd be if you carefully used manual focus to place critical focus exactly where you want it, and then the camera moves it to a different place when you push the shutter button.
Oct 21, 2013 at 09:13 PM
newtophoto
p.1 #4 · p.1 #4 · dumb question - af/mf switch
Gotcha, thanks. I already rear button focus so I guess this is a non issue.
Oct 21, 2013 at 09:14 PM
p.1 #5 · p.1 #5 · dumb question - af/mf switch
OK. So, you're not so "new to photo"; rear button AF isn't a typical noobie thing
Earlier points aside, it's worth noting that some lenses don't care where your AF button is set; they won't MF in AF mode, and vice versa.
Oct 22, 2013 at 12:24 AM
