garyvot Offline Upload & Sell: On
Andre Labonte wrote:
Thanks, this is helpful. I'm hesitant to go with the 60D figuring that for the price the T5i having a newer generation sensor would provide better high ISO performance. Am I correct that the T5i is a newer sensor and if so, has better performance?
Also, IQ and high-ISO is only part of the equation. But I don't have a feel for the 60D vs. the T5i with regards to AF performance, responsivness, etch.
It sounds like you're leaning toward the T5i, but in case you do consider a mid-range mode, here are a few thoughts on 70D vs. 60D:
- 70D has the new on-sensor phase-detect Live View AF system permitting smooth and quick autofocus for video capture (and much faster AF for stills, if you shoot that way).
- The rear LCD features touch controls and tap-to-focus
- The AF system is an updated/improved versrion of the 7D, quite a bit more advance than that 60D
- The 70D supports micro-focus adjust (MFA), while the 60D does not
- 70D has a faster framerate
I owned a 60D and it's a fine camera, but if the cost difference is not a bid deal, then the 70D is improved in some significant ways.
