garyvot Offline Upload & Sell: On
Except for the colors, that's about the inverse of my experiences with these two cameras, so something doesn't quite add up.
There are too many variables that could have influenced your results; I'd advise doing some formal testing with the cameras in known common configurations to be certain this is repeatable. Also, make sure you have calibrated your lenses to your body before evaluating AF performance.
Re. colors and WB: were you shooting JPEG or RAW? If JPEG (or processing your RAWs in DPP), your two cameras should produce very close results if using common Picture Style and WB settings. If you were using LightRoom or ACR, your results can certainly vary based on the camera profile in use. (When using ACR, I favor Adobe's profile for the 7D and its "Camera Standard" profile for the 5-series models. The colors aren't always identical, but the starting point in each case is pleasing.)
