Archive 2013 · D800 Flash Question
moosehead222
p.1 #1 · p.1 #1 · D800 Flash Question
I find it interesting that to use TTL vs TTL balance (using the built in flash) you have to be in spot meter mode. The 800 does not have a setting for straight TTL.
I normally use manual exposure mode with the flash set to minus whatever.
If you are in manual mode the spot meter has not impact other than changing the built in flash to use TTL vs TTL balance fill?
Is this correct?
I do not do a lot of flash so I am easily confused. Thanks
Oct 11, 2013 at 10:30 AM
NathanHamler
p.1 #2 · p.1 #2 · D800 Flash Question
you would be correct in that assumption....in manual mode, the meter is still controlling the flash output....that's where it references from, when you have the flash set to -1.0 ev, -2.0 ev, etc.....
Oct 11, 2013 at 11:54 AM
moosehead222
p.1 #3 · p.1 #3 · D800 Flash Question
ok thanks
Oct 11, 2013 at 12:15 PM
