Archive 2013 · Sekonic PW RT-32 Outdoor Range?
Jayem1
p.1 #1 · p.1 #1 · Sekonic PW RT-32 Outdoor Range?
Not sure if someone had similar experience with range issue of PW rt-32. I was testing strobe triggering outdoor using Sekonic L-358 with rt-32. The PW Plus II acted as receiver on strobe. I was standing just a few feet away and it failed to trigger the flash until I moved closer, maybe 3-4 ft. That surprised me as I thought the range would be much greater. I haven't noticed this in indoor settings. Am I missing anything?
Thanks in advance for your input.
Oct 09, 2013 at 07:04 PM
hondageek
p.1 #2 · p.1 #2 · Sekonic PW RT-32 Outdoor Range?
I've got an RT-32 in a Sekonic L-358 and the range is pretty bad. Sometimes it's only a few feet, somtimes more, sometimes it doesn't work at all. I end up putting the meter in standard flash mode and triggering with another PW.
Oct 09, 2013 at 07:28 PM
Jayem1
p.1 #3 · p.1 #3 · Sekonic PW RT-32 Outdoor Range?
Thanks, hondageek, for the info. At least I'm not alone. You would think the wireless range is greater than just a few feet.
Oct 09, 2013 at 08:21 PM
zurkzees
p.1 #4 · p.1 #4 · Sekonic PW RT-32 Outdoor Range?
I've had that issue in the past. A new fresh battery helps.
The battery indicator isn't really very reliable.
Oct 11, 2013 at 12:28 AM
Jayem1
p.1 #5 · p.1 #5 · Sekonic PW RT-32 Outdoor Range?
Thanks for the info. That makes sense. I can swap out the battery and try again, even it showed full on display.
Oct 11, 2013 at 01:10 PM
tsilva
p.1 #6 · p.1 #6 · Sekonic PW RT-32 Outdoor Range?
Just tried with my 758DR with RT32, PlusII, and 580EX. 758DR has low battery warning, PlusII has so-so batteries as does the 580EX. Fired every time at approximately 60ft. Not sure why you are having problems.
Oct 14, 2013 at 11:56 PM
