Archive 2013 · Two nex 6/7 questions / rx1
h00ligan
p.1 #1 · p.1 #1 · Two nex 6/7 questions / rx1
Borrowed a 6 - The 5/6 menus are killing me after using the rx1. Is the 7 more geared to organized layout?
Lis the rx1 evf better than the 6. I'm not impressed with the nex 6 evf. In lower light it's very laggy and peaking is poor
Oct 02, 2013 at 02:46 AM
ytwong
p.1 #2 · p.1 #2 · Two nex 6/7 questions / rx1
NEX-7 use the same kind of crappy menu as other NEX 3/5/6 series.
Oct 02, 2013 at 04:10 AM
jonrock
p.1 #3 · p.1 #3 · Two nex 6/7 questions / rx1
All the NEX cameras use the same menu. The RX-1 and the RX-100 I think both use a different type menu. You'll kind of get used to it with time though.
Oct 02, 2013 at 05:01 AM
LightShow
p.1 #4 · p.1 #4 · Two nex 6/7 questions / rx1
In that after you set up the camera you hardly ever have to go into the menu.
I hope that the new NEX's are released(FF & ?) that the menus will be updated, and older NEX's will get it too with a FW update
Oct 02, 2013 at 05:32 AM
ricardovaste
p.1 #5 · p.1 #5 · Two nex 6/7 questions / rx1
What are you using the menu for?
Oct 02, 2013 at 07:48 AM
ytwong
p.1 #6 · p.1 #6 · Two nex 6/7 questions / rx1
NEX-7 and 6 relies less on the menu compares to NEX-5/3, but one setting I frequently use, enable/disable OSS, is deep in the menu.
Regarding the EVF, it's lens dependent, if you use a faster lens, the sensor gets more light and it works better... if you use a 6.3 lens (like the long end of the 18-200 or 55-210 zoom), it'd be much worse than if you are using a 1.8 lens.
Oct 02, 2013 at 07:51 AM
sebboh
p.1 #7 · p.1 #7 · Two nex 6/7 questions / rx1
doesn't the latest iteration of the 5 have more alpha/rx like menus?
Oct 02, 2013 at 11:31 PM
h00ligan
p.1 #8 · p.1 #8 · Two nex 6/7 questions / rx1
thanks for the info. I really appreciate it. So far I'm only using it Kit zoom. Which frankly is awful. The old one the non power zoom was much superior in my opinion.
I did pop the 45g on there but its awkward with the metabones adaptor.
I used it today on a scouting trip and noticed really weird mustache distortion on the wide end of the kit lens
the sensor seems exactly the same as the 5n I sold
which is to say not too bad when paired with a good lines a question is what are the guidelines is right now? I'm contemplating possibly Touit 12 millimeter or trying the 10-18
But this house today...I can't see shooting it w/out a DSLR except for features.
To be honest I thought I'd be a bit more impressed with the 6, maybe its just the crappy kit lens letting it down.o really do think its a lot worse than the original. I'll see what I can borrow. Iso 3200 cleans up pretty well. I'm spoiled by full frame for sure.
Is the rx1 evf better than the next?
Here's a very crappy snapshot with the 6 and kit handheld. Like I said it was a scouting trip figured I'd take the nex Look at the ceiling line upper left. Yikes.
Oct 03, 2013 at 01:10 AM
douglasf13
p.1 #9 · p.1 #9 · Two nex 6/7 questions / rx1
Yeah, the power zoom is about the worst lens I've used on NEX, at least in my limited time with it.
Oct 03, 2013 at 02:24 AM
h00ligan
p.1 #10 · p.1 #10 · Two nex 6/7 questions / rx1
I was tempted to buy the nex 5r from best buy for $387. Just because it had a better kit lens. But ... I really really need to see the 10-18 results or touit 12.
Oct 03, 2013 at 05:52 AM
