Archive 2013 · Ikan 576 LED opinions
mrbill98
p.1 #1 · p.1 #1 · Ikan 576 LED opinions
Hello everyone, I just purchased this LED light a couple of days ago for studio work. Beautiful light, adj color
temp, remote, looks well made. It comes with a power adapter for in-studio use. HERES the GOTCHA !!!
If I want to make this light portable, the smallest capacity, dedicated battery, cost almost as much as the light. OUCH. Anybody use this light? What are your thoughts about investing in a portable power system??
HELP!! I can't take it back. Thanks
Sep 27, 2013 at 01:22 AM
400d
p.1 #2 · p.1 #2 · Ikan 576 LED opinions
The easy way is to buy a 12V battery (Lead Acid, NiMH, Li-Ion, LiFePO4), connect it to an inverter (min. of 100W), then just plug in the original AC adapter. The AC adapter should be switched mode power adapter so the inverter can be modified sine wave.
Advanced DIY is to buy a 4-pin XLR female connector (same pin-out as the light), and connect it to any 12V DC power source you have. It seems the light max. power draw is 82W, I'd say buy a battery with min. 10Ah capacity. You have to figure out the pins (positive and negative) yourself though.
Sep 27, 2013 at 03:26 AM
mrbill98
p.1 #3 · p.1 #3 · Ikan 576 LED opinions
Thanks 400d. That's good advice, as it mirrors what I was able to scour from other sites, after I got over the
initial shock. Thanks again
Sep 27, 2013 at 01:19 PM
