       2       3       end
Archive 2013 · Which walk around lens for 6D
bihani
p.1 #1 · p.1 #1 · Which walk around lens for 6D
I've canon 6D with 50mm and 100mm lenses.
I'll be traveling back home(India). So looking for all purpose / walk around lens.
Budget is about $600.
Please suggest.
Sep 26, 2013 at 12:34 PM
dgdg
p.1 #2 · p.1 #2 · Which walk around lens for 6D
24-105 f/4 IS used
Sep 26, 2013 at 12:38 PM
danh920
p.1 #3 · p.1 #3 · Which walk around lens for 6D
I second the 24-105
Sep 26, 2013 at 12:42 PM
CoDaQue
p.1 #4 · p.1 #4 · Which walk around lens for 6D
+ 40 2.8 STM.
Sharp and so very handy.
Sep 26, 2013 at 01:18 PM
surf monkey
p.1 #5 · p.1 #5 · Which walk around lens for 6D
50mm is a great walk around lens.
If you want to try wider, a 17-40 would work well with your primes.
Sep 26, 2013 at 01:33 PM
jasonpatrick
p.1 #6 · p.1 #6 · Which walk around lens for 6D
I never liked the 24-105 except on full frame. It makes a nice single lens combo with the 6d particularly because the 6d is slightly smaller than the 5dII/III. The 2.8 zooms add a bulk that can make the camera feel slightly out of balance. Personally I think I'm more creative with pretty much any other lens, but if walk around is what you want, it can do that really well.
Sep 26, 2013 at 01:39 PM
rebelshooter
p.1 #7 · p.1 #7 · Which walk around lens for 6D
24-105L is an ideal walk around. If you want something small, I would recommend the 35/2. I was not a fan of the 24-105 or the 35 on the crop, but I really like them on FF.
Sep 26, 2013 at 02:10 PM
p.1 #8 · p.1 #8 · Which walk around lens for 6D
I use the 24-105L IS and 100-400L IS as "walk around" lenses with my 6D.
Sep 26, 2013 at 02:41 PM
dhphoto
p.1 #9 · p.1 #9 · Which walk around lens for 6D
Tamron 28-75 or even a 24-85 if you use RAW, LR and the lens profiles
Sep 26, 2013 at 03:13 PM
abqnmusa
p.1 #10 · p.1 #10 · Which walk around lens for 6D
I use 40mm F2.8 as a 6D walk around
sharp lens, keeps setup small and light
sometimes using the Sigma 35mm F1.4
Sep 26, 2013 at 03:15 PM
Rytr
p.1 #11 · p.1 #11 · Which walk around lens for 6D
IMO the 24-105L would be hard to beat for a general all-purpose walk-around lens for the 6D. I like to use the 17-40L but the 24-105L would be my suggestion.
Sep 26, 2013 at 03:24 PM
dhphoto
p.1 #12 · p.1 #12 · Which walk around lens for 6D
I find the 24-105 a bit unbalanced on the 6D, plus it makes the combo bigger, which is why I mentioned two smaller lenses.
Sep 26, 2013 at 03:41 PM
SeattleBirdMan
p.1 #13 · p.1 #13 · Which walk around lens for 6D
24-105 for versatility.
Sep 26, 2013 at 03:49 PM
Gochugogi
p.1 #14 · p.1 #14 · Which walk around lens for 6D
The EF 24-70mm f/4.0L IS USM is ideal for the smaller form factor of the 6D, albeit a bit pricy still.
Sep 26, 2013 at 04:43 PM
erikburd
p.1 #15 · p.1 #15 · Which walk around lens for 6D
1) Used 24-105L
2) 40mm STM
3) 35mm f/2 (non-IS version)
Sep 26, 2013 at 05:21 PM
Bijltje
p.1 #16 · p.1 #16 · Which walk around lens for 6D
Looking at your other lenses I would pick a 28mm.
I always try to go for a 3 set of lenses and 28-50-100 is a classic one.
35mm is nice as well but I.M.O to close to 50mm.
I have a 28mm, 35mm and 50mm and always combine the 28 and 50 together. The 35mm I take when I only use one lens.
It is my preferred set at least
Looking at canon's offers on 28mm lenses, I would go for the 28/2.8 IS. The 28/1.8 isn't that good and the new 28 seems to do better.
Sep 26, 2013 at 07:00 PM
gregoryallen
p.1 #17 · p.1 #17 · Which walk around lens for 6D
24-105mm L....no contest for a general walk around.
Sep 27, 2013 at 03:43 AM
robsuh
p.1 #18 · p.1 #18 · Which walk around lens for 6D
With my 5D2, I much prefer the 28mm 2.8 IS over my 24-105L for walkaround. The 28mm 2.8 IS is so small and light that it is a pleasure to have around. Makes the 24-105L seem like a beast.
The 28mm also works great for events. Shot a wedding and b-day party with just it. Worked great.
The only time I reach for the 24-105L is oddly enough for portraits (senior, baby.) I guess also for landscapes, but I haven't done much of that recently.
Sep 27, 2013 at 04:50 AM
Paul Mo
p.1 #19 · p.1 #19 · Which walk around lens for 6D
I'd suggest the 70-300 f4-5.6L IS.
Sep 27, 2013 at 05:01 AM
johnctharp
p.1 #20 · p.1 #20 · Which walk around lens for 6D
I used my 70-300 non-L as a walkaround on a 60D of all things in Singapore... somehow it worked out
Sep 27, 2013 at 05:14 AM
       2       3       end
       2       3       end
