Archive 2013 · FS: OWC PC8500 4x4GB 1066MHZ and 2x8GB 1333MHZ , GTX660TI PE
nismoxr34
p.1 #1 · p.1 #1 · FS: OWC PC8500 4x4GB 1066MHZ and 2x8GB 1333MHZ , GTX660TI PE
 Item updated in the last 24 hours Item price reduced in the last 24 hours    OWC 4 x 4.0GB PC8500 DDR3 ECC 1066MHz 240 Pin
Item still Available
Price: $80.00
Slightly used OWC 4GB ram that will work in your mac pro, and more.
240-pin SDRAM DIMM
512M x 72, Dual Rank ECC Memory Module
Data Rate = 1066MHz
Module Bandwidth 8.5GB/s
CAS 7-7-7-20
Voltage 1.5V
Apple Specified Thermal Sensor*
RoHS Certified
 Item updated in the last 24 hours Item price reduced in the last 24 hours   OWC 2 x 8.0GB PC8500 DDR3 ECC 1333MHz 240 Pin
Price: $160.00
BRAND NEW OWC 8GB ram that will work in your mac pro, and more.
240-pin SDRAM DIMM
1024M x 72, Dual Rank ECC Memory Module
Data Rate = 1333MHz
CAS 9-9-9-24
Voltage 1.5V
RoHS Certified
 Item updated in the last 24 hours Item price reduced in the last 24 hours   MSI N660TI PE 2GD5/OC GeForce GTX 660 Ti 2GB 192-bit GDDR5 PCI Express 3.0 x16
Price: $280.00
I have a slightly used GTX660 TI Power Edition from MSI that I am looking to off load. I bought a new card so this one has to go. Comes with everything it came with new. If you have any questions, feel free to email
Edited on Oct 23, 2013 at 06:20 PM · View previous versions
Sep 25, 2013 at 04:02 PM
nismoxr34
p.1 #2 · p.1 #2 · FS: OWC PC8500 4x4GB 1066MHZ and 2x8GB 1333MHZ , GTX660TI PE
8GB RAM is NEW
4GB RAM is semi used. All prices are cheaper than manufacture! PM if interested.
Sep 27, 2013 at 03:12 PM
