pburke Offline Upload & Sell: Off
p.1 #9 · p.1 #9 · D600 won't respond after shooting tethered | |
some ideas -
charge the battery, press reset while there is none in there, leave the battery out overnight. There is always a backup battery in the body, so when you swap a battery the settings are not lost. That's what is keeping your messed up settings in place right now. On a computer I'd say pull the backup battery, but I don't know how to do that on a camera. It is confused, so do whatever you can to get it in a mode that changes its tether behavior.
Plug a wired remote in, change the shutter release to wireless and use a wireless trigger, go to bulb, etc basically try every mechanical switch you can to try to get it to snap out of tether mode. Remove the lens, put a different lens on. swap the memory cards, etc. Turn live view on. I bet you have done most of that, but who knows, one of these may just make those two green marked buttons come alive and then you can reset it with a 2 second simultaneous press on those.
