Archive 2013 · How to setup AEB in a 5D II
pinball
p.1 #1 · p.1 #1 · How to setup AEB in a 5D II
Hi all I have been trying to set up a canon 5D II in AEB to take 3 pictures for a HDR shot but can seem to set it up right, The manual is awful just what is the best way to set this up and can it be done in any mode?? thanks in advance
Bill
Sep 11, 2013 at 05:45 PM
dhphoto
p.1 #2 · p.1 #2 · How to setup AEB in a 5D II
I find the easiest way is to have the AEB as one of your My Menu items so you can get to it quickly.
Alternatively you can always assign an AEB setup to one of the C settings.
The manual does explain it very clearly
Sep 11, 2013 at 06:03 PM
pinball
p.1 #3 · p.1 #3 · How to setup AEB in a 5D II
ok I read the fine print have to hold the button down if in continuous shooting mode thanks for reply
Sep 11, 2013 at 06:16 PM
dhphoto
p.1 #4 · p.1 #4 · How to setup AEB in a 5D II
I use a 5D2 with AEB all the time and I have found the best way for me is to use liveview and the cordless remote (or a cheap ebay copy, which works fine), which fires all the exposures one after the other without the mirror going down at all for maximum stability and registration
Sep 11, 2013 at 06:18 PM
surf monkey
p.1 #5 · p.1 #5 · How to setup AEB in a 5D II
Holding down the shutter release button is not the best solution. It introduces a source for vibration and causes blurry images.
If you don't have a remote shutter release, use the 2 second timer release. One execution will shoot all three shots.
Sep 11, 2013 at 10:14 PM
