dsjtecserv Offline Upload & Sell: Off
This one has a lot of potential. But it has a very pronounced blue/cyan color cast. A degree of blue bias can sometimes work well, especially with water shots, but this is too much. I'd suggest taking it back to the raw stage and adjusting the overall white balance to reduce the blue. Move the blue-amber slider (or equivalent in your raw converter) to toward the warmer side, using a sampling eyedropper or equivalent so that the the bright (but not absolute brightest) tones of the water are near neutral. You can tweak it a bit from there if you want to preserve a cooler look, but that should be a good starting point.
Otherwise this is nicely composed and presented. You might consider cloning out the yellow branch at the top, as it is distracting. If the falls were surrounded by fall colors this wouldn't stand out, but as it is doesn't quite fit. This is a nice image and is worth some more work.
Dave
