rick2906 Offline Upload & Sell: Off
Ok I already had a mini tt1 flex tt5 to use with my Nikon flash! I was able to use my flash in manual mode and trigger it from my sekonic L-758 lightmeter. I bought a ac3 to be able to control my flash power remotely. But here come the problem, for the ac3 to work, the flash has to be in ttl mode and not manual!!| If the flash is in ttl mode then I can't trigger it from the sekonic flash meter. What would be my cheapest option to trigger my flash wirelessly compatible with the pocket wizard system?? I am really disapointed in these restriction, kind make the ac3 pointless if you can't use a flash meter to trigger the flash.
