Sam_W Offline Upload & Sell: Off
Not to throw cold water on this, but if you're going the route of two adapters (lens mount adapter plus speed booster), you're going to introduce enough mechanical tolerance variation/warping/etc. that you can end up with a seriously skewed focal plane, meaning that your infinity will only work for part of the imaging plane. Essentially you wouldn't be able to do proper landscapes. May not matter to you, though. (At the very least, Leitax whatever lens you end up going with, to eliminate one of those sources of variance.)
