Archive 2013 · D800 EN-EL15 vs. the old EN-EL3E
loudtiger
p.1 #1 · p.1 #1 · D800 EN-EL15 vs. the old EN-EL3E
Has anyone else noticed that their EN-EL15 battery gets "worse" on the battery health screen faster than the old EN-EL3E?
I shot a D300 from 2007 to 2012 and both batteries were still rated "0" on the screen. The D800's battery, on the other hand, is already showing "1". Granted, I'm not sure what the differences in reporting are between the two cameras, but it still seems a lot faster than before.
Aug 20, 2013 at 03:32 AM
EB-1
p.1 #2 · p.1 #2 · D800 EN-EL15 vs. the old EN-EL3E
My EN-EL15 are doing fine, but only a couple of years old. 5 years is a lot to expect without some degradation and most likely the battery info on the older battery is not so accurate.
Aug 20, 2013 at 04:16 AM
JimFox
p.1 #3 · p.1 #3 · D800 EN-EL15 vs. the old EN-EL3E
My D800 does great with the grip, the batteries don't seem to get "worse" any faster than the D300, if anything they last even longer than they did with the grip and the D300.
Jim
Aug 20, 2013 at 05:42 AM
mrgetalife
p.1 #4 · p.1 #4 · D800 EN-EL15 vs. the old EN-EL3E
Ignore the meter. Its just a feel good meter. The batteries have a finite life span based on time more than usage. I mean if you're a pro draining the battery every day. Yeah you'll wear it out. But you'll ignore the meter also. The only accurate meter is to use it and know how many shots you can get off from one charge. If that drops dramatically it means your battery has become defective.
Aug 20, 2013 at 06:00 AM
trenchmonkey
p.1 #5 · p.1 #5 · D800 EN-EL15 vs. the old EN-EL3E
I've got EN-EL15's almost 3 yrs old that I'd put up against my D700's EN-EL3e's, any day
Now the EN-EL4a's in da grip are a totally different animal....lasting forever! Worry when
yours read 3 or 4, as they drop like a rock from there.
Aug 20, 2013 at 11:43 AM
