Archive 2013 · D7000 file numbering
hsw21
p.1 #1 · p.1 #1 · D7000 file numbering
Hi Guys.
Im new with Nikon and I have a question.
I believe in D7000, the file number is from 0001 to 9999 per folder, right ?
My D7000 numbering ends at 0999 per folder, is this right ? Can I set it to end at 9999 per folder ?
Thanks.
Aug 18, 2013 at 09:03 AM
SRFast
p.1 #2 · p.1 #2 · D7000 file numbering
Refer to page 218 of the D7000 user's manual. You need to set the file number sequence option to "ON." If set to "OFF", a new folder will be created when the image count in the active folder exceeds "999". If you want the image number to reset to "0001" every time you format the memory card (setting "OFF"), a new folder will be created when the image count exceeds "999'.
Hope this helps...JL
Aug 18, 2013 at 06:31 PM
