Archive 2013 · More Nikon nonsense
Fstr.
p.1 #1 · p.1 #1 · More Nikon nonsense
Just an FYI, if you have a D3/D3X and need the right hand rubber grip, as of this posting it is off their parts store site. I was advised that I could send it in (yeah right) or check ebay (ok).
Aug 14, 2013 at 07:20 PM
Guari
p.1 #2 · p.1 #2 · More Nikon nonsense
Sure sucks.. but what's there to do?
Sad state of affairs
Aug 14, 2013 at 07:49 PM
DTOB
p.1 #3 · p.1 #3 · More Nikon nonsense
Or you could do what I did with my D700 and just glue that sucker back in place. It ain't pretty but it doesn't need to be.
Aug 14, 2013 at 09:48 PM
elmtree
p.1 #4 · p.1 #4 · More Nikon nonsense
DTOB, can I ask what glue you used on your D700? My grip is loose and I have been wanting to glue it but wasn't sure with what.
Aug 14, 2013 at 10:10 PM
NathanHamler
p.1 #5 · p.1 #5 · More Nikon nonsense
I've heard glue doesn't work.....i just get the thing lined up as best as possible, and throw a strip of gaff tape on it......does the job for me...
Aug 14, 2013 at 10:26 PM
Scott Grant
p.1 #6 · p.1 #6 · More Nikon nonsense
crazy glue works fine.
Aug 14, 2013 at 10:33 PM
DTOB
p.1 #7 · p.1 #7 · More Nikon nonsense
I used "industrial" hot glue as opposed to the normal stuff. Worked out fine, a bit messy. I should re-do the thumb grip, after a year it has started to give way again. That doesn't really bother me, doesn't change my grip.
Crazy glue would have been my choice if all the tubes I had lying around weren't dried up. Can't say it would have worked worse/on par/better.
Gaffers tape, yeah I can see that being a good solution too. Being a Canadian, I might be inclined to give hockey stick tape a go as well, it's nice and grippy, but leaves some serious residue should you decide to remove it not that I know why you would.
Aug 14, 2013 at 11:05 PM
Gene_C
p.1 #8 · p.1 #8 · More Nikon nonsense
Maybe Canon will suit your needs better Although this sounds like some kind of mix up more than anything.
http://www.fredmiranda.com/forum/topic/1234006
Edited on Aug 15, 2013 at 12:45 AM · View previous versions
Aug 14, 2013 at 11:54 PM
rattymouse
p.1 #9 · p.1 #9 · More Nikon nonsense
Nikon never fails to find moments to screw over their customers hard.
Aug 15, 2013 at 12:32 AM
RCicala
p.1 #10 · p.1 #10 · More Nikon nonsense
Actually, it's not glue that holds it on, it's double sided sticky tape. They actually sell the tape as a part (some of the better eBay sellers include the tape with a new grip).
But, you can also buy sheets of double sided tape and cut out your own. You'll need to make a couple of cuts (just like the original part) to make it bend around everything just right, but it comes on thick paper and is easy to do. They sell it on eBay and Amazon for $1 a sheet or so.
One other trick that sometimes works if the tape is still on but not sticky anymore: heat it with a hair dryer until it's warm to the touch. That sometimes restickifies it (I'm pretty sure that's a word).
Aug 15, 2013 at 12:40 AM
Fstr.
p.1 #11 · p.1 #11 · More Nikon nonsense
Pretty obvious that they want to repay our faith in the brand with a nickel and dime approach. Not a good way to run a business. We have a post your best image thread, maybe it is time for a post your complaint thread, by category. I really hate doing this (complaining).
Thanks for the tip Roger, worth a try.
Aug 15, 2013 at 12:49 AM
Erie Patsellis
p.1 #12 · p.1 #12 · More Nikon nonsense
Havy duty carpet tape works exceptionally well, btw.
Aug 15, 2013 at 02:00 AM
Gregstx
p.1 #13 · p.1 #13 · More Nikon nonsense
My camera is only a lowly D200 but I glued mine with a product named shoe goo (sp?) and that worked. Not messy if you are careful.
Aug 15, 2013 at 02:11 AM
jefflee
p.1 #14 · p.1 #14 · More Nikon nonsense
Greg - it may only be a "lowly" D200 but what colors at low ISO.
Aug 15, 2013 at 03:02 AM
DTOB
p.1 #15 · p.1 #15 · More Nikon nonsense
Totally forgot about shoe goo. It saved me so much money on shoes back when I could still skateboard.
Aug 15, 2013 at 03:08 AM
VJ218
p.1 #16 · p.1 #16 · More Nikon nonsense
Here you go. I found this site but it's currently out of stock right now.
http://procamerarepair.3dcartstores.com/NIKON-D3-D3s-RIGHT-SHUTTER-SIDE-RUBBER-REPLACEMENT-GRIP-_p_235.html
Aug 15, 2013 at 03:16 AM
robby521
p.1 #17 · p.1 #17 · More Nikon nonsense
few small drops of gorilla super glue and it wont never come off.did it with 2 of my cameras.
Aug 15, 2013 at 03:36 AM
Two23
p.1 #18 · p.1 #18 · More Nikon nonsense
the rubber zoom ring on my 17-55mm f2.8 has become stretched and almost useless. Maybe I should try the Gorilla glue--I have some laying around. No way I'm sending it in to Nikon.
Kent in SD
Aug 15, 2013 at 03:57 AM
Gregstx
p.1 #19 · p.1 #19 · More Nikon nonsense
Kent in SD
I don't think glue will fix a stretched zoom ring rubber. I sent my 18-200 DX lens into Nikon for a stretched zoom ring rubber. They replaced it under warranty and returned it quickly. Couldn't have been better handled by them.
Aug 15, 2013 at 04:30 AM
HauntedHat
p.1 #20 · p.1 #20 · More Nikon nonsense
This has been going on since at least last year, I believe, or as early as 2011, can't remember. I'd advice against using glue, it looks and feels awful (past experience), plus those parts are really cheap, compared to the camera you're using. Just send those guys (the pro camera repair folks) an e-mail, most of the time they have those parts in stock, but in small quantities, you need to ask for them.
The way I see it, you already spent a few grand on a digital body, the least you can do is buy a $20 part that will feel amazing in your hands, they just feel super grippy, in comparison to a well used grip. You can thank me later.
Aug 15, 2013 at 04:40 AM
