Archive 2013 · Any tips on increassing speed during import using LR5
IndyFab
p.1 #1 · p.1 #1 · Any tips on increassing speed during import using LR5
I have been using LR4 and the speed in which it loaded on import was fast.
After installing LR5 , it has decreased in speed considerably. Have set to minimal as I did on LR4
Anyone else experiencing this. Is there any settings in prefrences that may need to be unchecked.
Thanks for your time.
Jul 14, 2013 at 06:37 PM
BruceF99
p.1 #2 · p.1 #2 · Any tips on increassing speed during import using LR5
Turn off the Smart Previews if you don't have any need to edit the photos offline.
Jul 14, 2013 at 07:35 PM
IndyFab
p.1 #3 · p.1 #3 · Any tips on increassing speed during import using LR5
Thanks for the tip, but I never had "smart previews" on 4 and now 5. I was aware of that.
Jul 14, 2013 at 07:42 PM
Alan321
p.1 #4 · p.1 #4 · Any tips on increassing speed during import using LR5
Do you have Lr save the catalog and optimise it when you exit Lr ?
Jul 15, 2013 at 04:50 PM
15Bit
p.1 #5 · p.1 #5 · Any tips on increassing speed during import using LR5
From the testing I did a few weeks ago, there is practically no difference between LR 4 and 5 in speed terms. So if you have the same import settings ticked it might not be LR.
Are you saving the files over a network, or do you have network attached drives that are slow to respond? (LR may try to ping all connected drives in the import module).
Are you sure your CF card and reader or hard disk haven't chosen now to go bad?
Jul 17, 2013 at 03:59 AM
pjny
p.1 #6 · p.1 #6 · Any tips on increassing speed during import using LR5
I switched from LR 4-5 and noticed no difference in import speed. I have 2011 MBP 2.3ghz i5 with 16gb and LR was never that fast on the import. I use PhotoMechanic 5 to ingest, browse, select and caption images and then transfer them to LR 5. PhotoMechanic 5 is way, way faster in this respect.
BTW, do you have "Automatically write changes into XMP" on in Catalog Settings?
Jul 19, 2013 at 06:59 PM
