Archive 2013 · Date and time on front of prints. How?
jcbradshaw
p.1 #1 · p.1 #1 · Date and time on front of prints. How?
A friend needs to display prints with the date and time he took them on the front of the prints. I have Lightroom 4 and PS CS6. Is there a way I can do this for him?
Thanks,
Jeff
Jul 09, 2013 at 03:44 AM
BruceF99
p.1 #2 · p.1 #2 · Date and time on front of prints. How?
Create a watermark in LR or a text layer in PS.
Jul 09, 2013 at 04:23 AM
jcbradshaw
p.1 #3 · p.1 #3 · Date and time on front of prints. How?
I was hoping there was something that could take the exif data and put the date and time on the front automatically.
Jul 09, 2013 at 04:24 AM
Mr Mouse
p.1 #4 · p.1 #4 · Date and time on front of prints. How?
If you friend has not striped his images files EXIF meta date. With CS6 all he would need is a Photoshop script to retrieve the exif data he want added to the image and add it as a text layer. Do search for a Photoshop exif script.
http://mouseprints.net/old/dpr/Examples/StampEXIF.jpg
http://mouseprints.net/old/dpr/Examples/ShowEXIF-2.jpg
Jul 09, 2013 at 04:56 AM
jcbradshaw
p.1 #5 · p.1 #5 · Date and time on front of prints. How?
Thanks Mr. Mouse. I'll give that a try.
Sure wish LR would let you do this on export.
Jul 09, 2013 at 06:20 AM
howardm4
p.1 #6 · p.1 #6 · Date and time on front of prints. How?
If it was me, I'd combine Lightroom, ImageMagick, Exiftool, command line scripting and Jeff Friedl's 'Run Any Command' LR export plugin to create a during-export script to extract the data and then 'place' it on the image.
But I'm more comfy w/ that than extensive PS actions etc.
Jul 09, 2013 at 10:56 AM
hugowolf
p.1 #7 · p.1 #7 · Date and time on front of prints. How?
Lr will do it, but not over the image, just underneath the image. You would use Print to FIle.
Brian A
Jul 09, 2013 at 01:35 PM
jcbradshaw
p.1 #8 · p.1 #8 · Date and time on front of prints. How?
Brian,
Under the photo is fine. In fact even better. I just want it on the front of the print. I see in the print module that I can add photo info and choose date, etc. Is that what you are talking about? I haven't found "print to file", unless you are saying to print it to a computer file like like "Microsoft Document Writer" instead of on a printer.
And adding photo info in the print module gives me choices, including dates, but not date and time. Am I missing something?
Jeff
Jul 09, 2013 at 01:58 PM
James_N
p.1 #9 · p.1 #9 · Date and time on front of prints. How?
The LR 2/Mogrify plug-in for Lightroom will do exactly what you're looking for: http://www.photographers-toolbox.com/products/lrmogrify2.php?sec=quickguide
You simply choose to Export the image from Lightroom, and in the Export Dialog box you configure LR 2/Mogrify to print any or all of the EXIF Metadata in any position you want. See the example in the "Text Annotations" section of the QuickGuide link above. Note that you can use tokens that will extract the specific metadata and add it to the photo.
Jul 09, 2013 at 02:00 PM
jcbradshaw
p.1 #10 · p.1 #10 · Date and time on front of prints. How?
I will give that a try. Thanks!
Jul 10, 2013 at 04:28 AM
mshi
p.1 #11 · p.1 #11 · Date and time on front of prints. How?
You can write a Photoshop script to do it. If you don't know how to write it, just google it up and there should be many out there. If you use PhotoMechanic, you can export to jpg by adding a watermark with {date} variable, which automatically inserting the date based on exif on each image.
Jul 10, 2013 at 04:58 AM
