Sports Corner Rules
Sports Corner Resource
Archive 2013 · Pitching Comp
jmcaverly
p.1 #1 · Pitching Comp
Ted Ellis posted some nice pitching composites over the last couple of years and I always wanted to give one a try. I mounted my camera on a tripod and rattled off a few shots and composited three of them here. My photoshop cut out skills are middle of the road at best, but I enjoy working on the compositing process. Just wondering what others thought of the layout of this composite, still a work in progress. C&C always appreciated.
Jeff
Jun 12, 2013 at 09:25 PM
DPC1
p.1 #2 · Pitching Comp
I like this! I like this a LOT! Very cool sequence!
You have some halo around the player's arms and legs, but that can be easily fixed.
Are you using Photoshop? If so, which version?
Jun 12, 2013 at 10:04 PM
cocodrillo
p.1 #3 · Pitching Comp
Nicely done. This is one of the better composites posted in terms of not losing the eye in too many limbs.
Jun 13, 2013 at 05:58 AM
jmcaverly
p.1 #4 · Pitching Comp
I have the latest version of photoshop. Thanks for the input.
Jun 13, 2013 at 06:36 AM
Ted ellis
p.1 #5 · Pitching Comp
Jim:
A very good looking composite. If I were the father of the pitcher, I wouldn't think twice about buying your composite.
I have tried the traditional and non-traditional composites. You might try pulling the 2nd pose back a tad so the push off foot is on top first foot. Then pull the heel of the third back to the front foot of the 2nd.
Another suggestion is do you have an earlier starting pose?
Nit picking now when one outlines an image cuts and pastes lines are visible. The tedious work is to clean those up.
Hope this helps Jim.
Ted
Jun 13, 2013 at 02:57 PM
jmcaverly
p.1 #6 · Pitching Comp
Ted ellis wrote:
Jim:
Ted
Thanks for the input Ted. I do have another starting pose. I will keep working on the cutouts and hopefully come up with something better.
Jeff
Jun 13, 2013 at 11:40 PM
Ted ellis
p.1 #7 · Pitching Comp
Jeff
Jeff, I like this composite. I was only suggesting a different look. Your composite got be to thinking about the first composite I posted here on Sports Corner so many years ago. I did a redo.
Ted
Jun 18, 2013 at 02:51 PM
jmcaverly
p.1 #8 · Pitching Comp
Thanks Ted. Have been busy, but I plan on working on a few more variations. As soon as I make progress, I will post them.
Jeff
Jun 18, 2013 at 03:09 PM
jmcaverly
p.1 #9 · Pitching Comp
I worked on the original composite a little more. Started to clean up the cutouts and I moved the last frame to the right a little. C&C appreciated.
Jeff
Jun 18, 2013 at 09:51 PM
Ted ellis
p.1 #10 · Pitching Comp
Better Jeff.
Ted
Jun 19, 2013 at 05:30 PM
cowski54
p.1 #11 · Pitching Comp
make sure he remembers his belt next time
Jun 20, 2013 at 10:24 PM
Bark Imaging
p.1 #12 · Pitching Comp
I think you ought to trade ISO for shutter. Get the motion perfectly frozen, even the arm. The cutouts will be sharper and since you're going to be heavy processing anyways noise reduction is easier to manage than motion blur. But these are awesome!
Jun 21, 2013 at 09:39 AM
glennh56
p.1 #13 · Pitching Comp
Very nice, is this all from the same burst?
Jun 21, 2013 at 07:07 PM
Tom D
p.1 #14 · Pitching Comp
This is a clean comp, Jeff. The only thing I'd mention is that the larger space between the ball and right frame in the first version leaves more room for the pitcher to 'throw into', and feels more comfortable to look at.
Good looking image, though. Nice work...
Jun 23, 2013 at 11:12 AM
jmcaverly
p.1 #15 · Pitching Comp
His dad was teasing him about the same thing.
Jun 23, 2013 at 04:04 PM
jmcaverly
p.1 #16 · Pitching Comp
I shot a few differnt bursts of three each and chooose from them. I wish I would have gotten a different first shot on the left and will give it another go later.
Jun 23, 2013 at 04:07 PM
jmcaverly
p.1 #17 · Pitching Comp
Thanks for the comments.
jmcaverly
p.1 #18 · Pitching Comp
I agree. The last image is too tight to the right. I did not shoot enough of his pitching sequence to get a good choice of images to pick from. I am going to try to get some more and put together another. Thanks for the comments.
Jeff
Jun 23, 2013 at 04:09 PM
markedman
p.1 #19 · Pitching Comp
Great image. Is there a tutorial on this? What would the process be called?
Jun 26, 2013 at 08:59 AM
