Archive 2013 · UWA Camera / Lens Combo's ...
RustyBug
p.1 #1 · UWA Camera / Lens Combo's ...
Mirror or Mirror-less ... Fixed or Interchangeable body ... Prime or Zoom lenses ... Manual or AF.
It's all fair game, any brand ... make your pitch ... even P&S if it's good enough (IQ performance, not convenience factor).
Recommendations that are well-corrected rectilinear close to 16mm (14-18 FF equivalent) compared to the Tokina 16-28/2.8. A fast aperture is not a major issue, as it will mostly likely be used @ 5.6 or 8 for dof purposes ... well corrected (no mustache distortion, nominal CA, no vignetting stopped down, good corners) for interiors.
It's getting to be time for an upgrade to my Tamron 17-35/2.8-4. ATM, I'm seeing the Tokina on as my best option on FF (which is fine), or the 17 TS-E. But exploring other options before I go that route. Working on getting my gear together for Better Homes & Garden.
Thoughts
Edited on Jun 10, 2013 at 11:36 PM · View previous versions
Jun 10, 2013 at 11:20 PM
FlyPenFly
p.1 #2 · UWA Camera / Lens Combo's ...
X-E1 + Fuji 14mm... although I guess that's only 21mm and you would have to deal with possible foliage issues.
mpmendenhall
p.1 #3 · UWA Camera / Lens Combo's ...
My only lens in that focal range is the Oly OM 18/3.5 (on Canon FF). Biggest advantage: not being big (doesn't look like that's a priority for you). Sharpness and lack of distortion are rather good. Largest optical downside is a lot of vignetting from wide open, persistent even when stopped down --- however, vignetting can be moderately well fixed in post-processing; so, considering a "whole system" solution that includes a preset in your image processing program of choice, vignetting is under control. This probably isn't the perfect lens for your specifications, but might not be completely counted out of the running.
Jun 10, 2013 at 11:43 PM
RustyBug
p.1 #4 · UWA Camera / Lens Combo's ...
Oly 18/3.5 on FF ... already there.
I have a hard time using it for production interiors ... "too skeered" I'll bugger it up knockin' around tight spaces, etc. Silly, I know, but it gets in my head and I can't get "in the zone" when I use it inside.
I'm figuring that I'll swap out my Oly 18 (did I actually say that) and the Tamron 17-35 for Right now the Tokina 16-28/2.8 and the Canon 17 TS-E are contenders ... exploring "alternatives" @ "all is fair game" before I commit to such a change.
Edited on Jun 11, 2013 at 12:28 AM · View previous versions
Jun 11, 2013 at 12:12 AM
Gunzorro
p.1 #5 · UWA Camera / Lens Combo's ...
Canon 17 TS-E.
Put it on your favorite 20MP+ Canon FF body (5D2, 1Ds3, 6D, 5D3, even the 18MP 1DX).
You'll always send me a Xmas card thanking me.
Jun 11, 2013 at 12:22 AM
Massimo Foti
p.1 #6 · UWA Camera / Lens Combo's ...
I have no experience with TS lenses. So far I have been very happy with my Tokina 16-28 on a canon 5DIII
Here some recent samples, hope you don't mind the military subjects:
Schutzenpanzer Marder 1 A3 by Massimo Foti, on Flickr
Zielpanzer 68 M-77876 by Massimo Foti, on Flickr
OT-810 late by Massimo Foti, on Flickr
Jun 11, 2013 at 06:30 AM
PhotoMaximum
p.1 #7 · UWA Camera / Lens Combo's ...
If you want pro quality production for interiors with sharp corners and almost zero CA then just get the 17 TSE. I am very happy with mine. Being able to shift to maximize interior details while minimizing ceilings is amazing...
Jun 11, 2013 at 06:56 AM
ISO1600
p.1 #8 · UWA Camera / Lens Combo's ...
From what I'm hearing right now, and most of what I've seen/heard/read, the 17TSE is a winner.
Jun 11, 2013 at 06:59 AM
FlyPenFly
p.1 #9 · UWA Camera / Lens Combo's ...
The other nice awesome option is the Panasonic 7-14mm.
Jun 11, 2013 at 07:07 AM
Massimo Foti
p.1 #10 · UWA Camera / Lens Combo's ...
If the main application is interior/architecture, pretty much nothing can beat a good TS
Jun 11, 2013 at 07:10 AM
ISO1600
p.1 #11 · UWA Camera / Lens Combo's ...
But make sure you use it on a Panasonic camera, unless you want to compromise with potential purple blobs....
(re: Panny 7-14)
If you'll consider M4/3, and Olympus at that, stick with Olympus lenses for best compatibility and no issues.
Jun 11, 2013 at 07:11 AM
kiddik
p.1 #12 · UWA Camera / Lens Combo's ...
+ for the 17 TS-E - I've tried countless wide-angles over the years and nothing comes close, not the same country even. Almost completely free of distortions, vignetting and CA (given that you don't shift). Once you get it, you stop looking at other wide-angles, saving you tons of money in the end!
Jun 11, 2013 at 07:31 AM
RustyBug
p.1 #13 · UWA Camera / Lens Combo's ...
+1 @ 17 TS-E is likely top option @ FF. Just not quite sure I'm ready for THAT much of an upgrade. I've got my 24L TS-E II, so I'm good with understanding the 17 TS-E option. Just kinda hard for me to put that kind of $$$ into two TS-E's ... i.e. budget killer (yeah, I know ... in the long run).
That, and I'm thinking about augmenting a smaller format (different reason), so I was wondering if any of the smaller formats have "come of age" with regard to excellent UWA options @ smaller formats that I should not overlook ... just trying to be open minded @ FF vs. crop vs. 4/3 vs.
Jun 11, 2013 at 08:29 AM
FlyPenFly
p.1 #14 · UWA Camera / Lens Combo's ...
I've always wondered if the Olympus 9-18mm for 4/3rds was any good as the MFT version of it is expensive and feels cheaply made just like the 14-42mm Mk2 kit lens.
Jun 11, 2013 at 08:30 AM
mpmendenhall
p.1 #15 · UWA Camera / Lens Combo's ...
And switching to the 3x more expensive 17mm TS-E, with its gigantic bulging front element, will set your mind at rest?
Jun 11, 2013 at 08:42 AM
RustyBug
p.1 #16 · UWA Camera / Lens Combo's ...
Not really ... part of reason for looking @ other smaller format options or the (not 3X $$$) Tokina.
I protect my 24L TS-E with a filter for the $$$ invested. Of course, the 17 TS-E would be "naked" ... just a bit of a nervous nellie here @ that $$$ level (not my comfort zone for knockin' around).
So, @ upgrade strategy, I might be playing for "second fiddle" instead of 1st chair on this one.
With all the prolific dialogue @ how "FF is dead", just wondering if our extensive pool of Alt Users might have a viable smaller format solution for quality UWA interior images.
Jun 11, 2013 at 08:47 AM
Gunzorro
p.1 #17 · UWA Camera / Lens Combo's ...
Rusty -- I've had the same concern about the bulging front element. But you just get used to it, and protect it from getting banged. Ultimately, a small nick is not going to show in pictures, and from what I understand, replacing the front glass is not that uncommon or excessively expensive.
With a little patience and a lot of looking here and on eBay, I found a very nice used version (the 17 TS-E design is only a few years old!) for just over $1800 . Mine got badly banged/jostled in transit by UPS (insured) and the seller repaid me for Canon adjustment (around $120 with CPS Gold).
I was soooooo impressed with the detail and contrast of this lens! You know how much discussion there is here on Alt about micro-contrast and such -- I usually stay far away from such discussions -- but the first images I got off the lens really popped! And I've got (or had) the 14 Samyang, 16-35L II, ZE 21/2.8, and 24 TS-E.
Like I say, you'll want to send me annual thank you cards if you get it.
This is the "Alt-iest" lens I own.
Jun 11, 2013 at 10:15 AM
Jman13
p.1 #18 · UWA Camera / Lens Combo's ...
Yup. Incredible lens. Just super sharp to the corners, and foliage for me hasn't really been an issue with the latest RAW converters. Here's a full size image from the X-E1 and 14 at f/8, straight from RAW with Capture One 7. Look at the detail in the lower left corner:
http://www.jordansteele.com/2013/xf14_full.jpg
Jun 11, 2013 at 10:21 AM
mcbroomf
p.1 #19 · UWA Camera / Lens Combo's ...
FF Canon : 17mm TSE, 18mm Distagon and OM good but trailing in the corners
Nex : Sony 10-18mm (12mm Tootit )
m4/3 : Panny 7-14
Mike
Jun 11, 2013 at 11:42 AM
FlyPenFly
p.1 #20 · UWA Camera / Lens Combo's ...
That does look quite good. I wonder when Adobe ACR will catch up.
Jun 11, 2013 at 11:44 AM
