jcolwell Offline Upload & Sell: On
p.1 #6 · p.1 #6 · The CF card shows empty on my computer. . . Need some help | |
jamato8 wrote:
I don't plug the camera into the computer, I use my firewire card reader. It shows up and shows the files but no images show up and it shows the CF card with most of the gb intact, not used.
OK, gotcha.
jamato8 wrote:
Sorry, you can or I can laugh about this.
I have the 5DIII. Two cards. . . . Yes, I always use the CF card but the camera put the images on the SD card I had installed. I don't mind the SD card in my M9, as I have no choice, but I prefer the CF card so. . I wish there was a way to make sure that the CF card is always chosen when it is put in the camera rather than having to do it each time you take the CF card out.
Been there, with most of my 1D-series cameras. The quickest way to ensure that it's using the card that you want it to (aside from checking the LCD and using some button pushes) is to have only the desired primary card in the camera when you turn it on. You can add the SD card later, and it won't switch to it.
