Wedding Resource List
Archive 2013 · JPG mini software
Jamesbjenkins
p.1 #1 · JPG mini software
Hey all,
I'm sure many of you are already aware of this piece of software, but I just found it yesterday, and I'm VERY excited about it's potential to speed up my workflow.
It's called JPEGmini and it's only purpose is to somehow compress a JPG image file while keeping all visible quality in the image. I'm not sure how their algorithm works, but I inspected on some of my own images, and I can't tell any visible differences after I run JPEGmini on a batch of images, even when inspecting at 1:1.
I ran it on a batch of images I recently uploaded to my proofing gallery for a client, and it reduced the file size by an average of 300%. I typically see file sizes of 7-8 MB and sometimes 12MB or higher with images I've done lots of work on in PS. After running JPEGmini, the average is less than 3MB per file. FWIW, I shoot with a D3s and a D3.
The full version of the software is $19.99, but there's a free version that lets you run up to 20 images per day.
You can check it out for yourself at JPEGmini.com
**disclaimer: I have no financial interest in JPEGmini, I just found it to be very helpful and thought the community here would appreciate the recommendation.**
May 19, 2013 at 03:19 PM
amonline
p.1 #2 · JPG mini software
Not sure what you're doing in PS, but my full size prints uploaded to the lab only run about 2-3mb. Even 11x14's only top out at 5mb. I see no visual differences in those either. Are you doing all your exports on level 12?
May 19, 2013 at 03:32 PM
mauri
p.1 #3 · JPG mini software
I've been using it for a while and I would say that on most pictures it does a great job...but not on all pictures. You do get artefacts in some images, specially when you have gradients on the sky, at least that's my experience. I use it on the files on my website because it does speed up the loading times a lot. All pictures on my website got the JPEGmini treatment
May 19, 2013 at 03:50 PM
Jamesbjenkins
p.1 #4 · JPG mini software
Alan, I must be doing something wrong then. I consistently run 6 or 7MB for all my completed files, exported from LR4 at 100% quality.
Now, perhaps the problem is that I'm converting from a TIF to a JPG on export. I may need to clean up my workflow. I just always thought that those sizes were normal...
It's a real pain trying to upload 500 files that large to my merchant website...
May 19, 2013 at 05:26 PM
D. Diggler
p.1 #5 · JPG mini software
I'm running 3 megabytes per 21-megapixel jpeg.
May 19, 2013 at 05:44 PM
amonline
p.1 #6 · JPG mini software
Well, now we're talking about different things. You mentioned PS originally. 100% quality out of LR for a client's finals is overkill. 85% is more than fine. PS on 10 and LR at 85 result in similar file size.
May 19, 2013 at 07:23 PM
D. Diggler
p.1 #7 · JPG mini software
amonline wrote:
PS on 10
That's what I use: 10. I heard there's no visual difference in a print made from 10 vs. 12.
May 19, 2013 at 07:33 PM
deepbluejh
p.1 #8 · JPG mini software
I have no problems with normal jpegs personally. It's those darn RAW files I wish were smaller.
May 19, 2013 at 08:02 PM
Jamesbjenkins
p.1 #9 · JPG mini software
Sorry, I should have clarified. I do the majority of my post work in LR, then run anything that needs extra edits through photoshop and back into LR for export/upload. I'll take a look at 85% quality on my JPGs, thanks for that tidbit.
May 19, 2013 at 11:44 PM
tonyhart
p.1 #10 · JPG mini software
If you're interested in quality and JPEG export via Lightroom then the below link is very interesting. Everything is not as it seems. 85 and 86% quality for example will result in the exact same file size. Take a look, it's extremely revealing:
http://regex.info/blog/lightroom-goodies/jpeg-quality
Edited on May 20, 2013 at 07:40 AM · View previous versions
May 20, 2013 at 03:37 AM
Jamesbjenkins
p.1 #11 · JPG mini software
tonyhart wrote:
If you're interested in quality and JPEG export via Lightroom then the below link is very interesting. Everything is not as it seems. 83 and 85% quality for example will result in the exact same file size. Take a look, it's extremely revealing:
Tony, thanks for sharing that article. I never knew most of those facts. My workflow will be changing immediately. No more 100% quality JPG on export...
May 20, 2013 at 07:04 AM
maxwell1295
p.1 #12 · JPG mini software
That's a great link!
There appears to be a huge difference in file size between exporting at 84% and 85% (I've been using 85%). 84% results in a significantly smaller file size with no loss in quality. I guess I'll be tweaking my export presets.
May 20, 2013 at 07:27 AM
tonyhart
p.1 #13 · JPG mini software
No worries, the chap who did the work is the one who deserves the praise!
May 20, 2013 at 07:39 AM
Njphotostudio
p.1 #14 · JPG mini software
Check this one and it is free. Plus you can add watermarks.
http://www.bordermaker.nl/en/
May 23, 2013 at 02:31 PM
BigIronCruiser
p.1 #15 · JPG mini software
Jeffrey Friedl's analysis is terrific. After reading it a year or so ago, I changed my LR export settings (for 4x6 prints) to 83% for quality, and 6" on the long edge. The average jpeg is 700KB, and at 4x6 they print just fine.
May 24, 2013 at 08:27 PM
scottam10
p.1 #16 · JPG mini software
I agree that Jeffrey Friedl's analysis is terrific - thanks for the link!
I think that JPG quality is lost every time you re-save the file, so I would avoid a workflow that involves saving in Photoshop (or Lightroom) and then using a separate program to re-save a reduced file size (eg JPEGmini)
- I think you're better off just saving once - choose a lower quality setting when you export to JPG from PS (or LR)
May 25, 2013 at 12:23 AM
