Archive 2013 · RAW post processing sharpening - 5D mark III
Yaniv
p.1 #1 · p.1 #1 · RAW post processing sharpening - 5D mark III
How much do you usually sharpen your RAW file in photoshop CS5?
Using the 25% default value I get soft images and i usually go up to 50%-60%
Am i missing something?
May 13, 2013 at 03:01 AM
dgdg
p.1 #2 · p.1 #2 · RAW post processing sharpening - 5D mark III
You are not providing any detail about your photos. Your issue could be anything from technique, lens, camera, and/or post processing.
For productive help, you should to provide example photos with exif data.
May 13, 2013 at 03:18 PM
colinm
p.1 #3 · p.1 #3 · RAW post processing sharpening - 5D mark III
50 or 60 on the Sharpness slider is really, really high on an in-focus image. Example photos would definitely be helpful.
May 13, 2013 at 03:26 PM
Yaniv
p.1 #4 · p.1 #4 · RAW post processing sharpening - 5D mark III
OK here we go:
This is with the default 25% settings:
25%
This is with 65%
65%
May 14, 2013 at 12:43 AM
dgdg
p.1 #5 · p.1 #5 · RAW post processing sharpening - 5D mark III
Both look just fine to me! I'd move on....
May 14, 2013 at 02:44 AM
Beni
p.1 #6 · p.1 #6 · RAW post processing sharpening - 5D mark III
I use 75,1,30,0 in ACR as a starting point but then that's all the sharpening I do. The amount is going to change drastically depending on your radius and detail.
May 14, 2013 at 08:14 AM
jhg photo
p.1 #7 · p.1 #7 · RAW post processing sharpening - 5D mark III
In ACR of CS6, I am routinely using 50, 1, 25-40, 20-25.
Very high ISOs like 6400 especially when underexposed seem to benefit from less sharpening and larger radius and more masking, e.g., 35-40, 1.5-2, 35, 30.
On print, the all look far better than on screen.
May 14, 2013 at 08:57 AM
