cputeq Offline Upload & Sell: Off
p.1 #2 · p.1 #2 · 5d3 sleeps between shots fired, can't move af point? | |
It's hard-coded to do that, just like my 5D2 did (IIRC). You cannot move AF points until you wake up the meter, and unfortunately the meter on the 5D3 only stays active for about 4 seconds (presumably to save power).
You can try to adjust meter timer option, but that only refers to AE lock timing, not actual usage timeout. Working as normal. I just make it a habit to quick tap the AF-On before changing AF points, etc.
