p.1 #1 · Elinchrom beauty dish replacement mounting ring
Hi all!
Long time no speak. I have a problem where the mounting ring on my beauty dish has been bent and needs replacing. There is no spare part available from Elinchrom. There are many mounting/adapter rings available in the repair centre but don't look like they will fit so well due to their size.
Has anyone had any experience with this and found a solution?
p.1 #3 · Elinchrom beauty dish replacement mounting ring
If you drill out the rivets holding the existing ring in you should be able to use just about any aftermarket speedring. I have an extra Photoflex ring and it matches up with mine as far as hole size and depth. You cold then drill the ring's edge and secure ti with a few short 8/32 screws and nuts.
