Archive 2013 · EOS Digital Solution Software available for download
Admin
p.1 #1 · EOS Digital Solution Software available for download
Canon has made the complete EOS Digital Solution Disk Software Disk v28.1A available for download.
EOS Digital Solution Disk Software is a software suite containing the applications "Digital Photo Professional", "EOS Utility" and "Picture Style Editor", dedicated for users who cannot use the bundled CD to install the suite.
Download: EOS Digital Solution Disk Software
(Before downloading you must provide your camera serial number - including all zeros)
____________________
Digital Photo Professional: This software is recommended for users who mainly shoot RAW images. You can quickly view, edit, process and print RAW images. You can also edit JPEG images while retaining the original images.
EOS Utility: With the camera connected to a computer, EOS Utility enables you to transfer still photos and movies shot with the camera to the computer. You can also use this software to set various camera settings and shoot remotely with the computer connected to the camera.
Picture Style Editor: You can edit Picture Styles and create and save original Picture Style files.
This package contains the following version applications:
Digital Photo Professional 3.13.10
EOS Utility 2.13.10
Picture Style Editor 1.13.10
May 08, 2013 at 10:49 AM
gvg45
p.1 #2 · EOS Digital Solution Software available for download
Nice option for people that have the newer laptops without a CD drive.
May 08, 2013 at 11:11 AM
woward
p.1 #3 · EOS Digital Solution Software available for download
Canon wants a camera serial number before downloading this application. I have a 1DMIII but the web site won't accept that S/N. Any suggestions or alternative ways of downloading the software?
May 08, 2013 at 11:25 AM
chmod
p.1 #4 · EOS Digital Solution Software available for download
I've seen times when I needed to strip some zeros off a serial for their system to accept it. Have you tried permutations?
May 08, 2013 at 11:29 AM
woward
p.1 #5 · EOS Digital Solution Software available for download
I've tried different approaches. It keeps coming back saying "your product is up to date - you do not need this upgrade..."
May 08, 2013 at 11:35 AM
billk55
p.1 #6 · EOS Digital Solution Software available for download
I'm in the same situation woward - I've got a 5DII and it won't accept the serial number.
What a foolish requirement in any situation. I have a feeling this will leak onto the web before too long. Last time, I had to use that approach.
May 08, 2013 at 11:46 AM
billk55
p.1 #7 · EOS Digital Solution Software available for download
Figured my problem out - I thought it wanted one of those numbers from the side of the Camera box. No, it wanted the number from the bottom of the camera (near the mounting plate screw hole).
May 08, 2013 at 11:54 AM
Gochugogi
p.1 #8 · EOS Digital Solution Software available for download
The boxes numbers are UPN, basically part/stock numbers. The serial number is in the ROM (view in EOS Utility) or on the bottom of the camera if used gently. After 4 years, my 5D2 serial numbers have worn almost completely off.
May 08, 2013 at 12:22 PM
Danny Michael
p.1 #9 · EOS Digital Solution Software available for download
I just went online to my Canon registrations and used that number from my 5D.
Thanks for the heads up, Fred.
May 08, 2013 at 12:43 PM
corndog
p.1 #10 · EOS Digital Solution Software available for download
Plenty of photos of the bottom of cameras on fleabay...just sayin.
May 08, 2013 at 01:06 PM
netmonster
p.1 #11 · EOS Digital Solution Software available for download
What could be the problem if I post a direct link to it?
May 08, 2013 at 01:14 PM
canonguy4ever
p.1 #12 · EOS Digital Solution Software available for download
I used a serial number from my old 5d. Worked great. Thanks Fred.
May 08, 2013 at 01:25 PM
AbramG
p.1 #13 · EOS Digital Solution Software available for download
A little odd to require the serial I guess, but I can confirm that my 5D2 serial worked just fine.
May 08, 2013 at 01:27 PM
woward
p.1 #14 · EOS Digital Solution Software available for download
Thanks everyone - I "found" a serial number that worked.
May 08, 2013 at 01:50 PM
ruhikant
p.1 #15 · EOS Digital Solution Software available for download
I used to download an old version that installs by itself and update to the newer version of DPP when I lost my CD.
http://web.canon.jp/Imaging/sdl/data/dpp100-e.exe
May 08, 2013 at 01:51 PM
johnahill
p.1 #16 · EOS Digital Solution Software available for download
This is handy for the used market where original disks may be missing.
May 08, 2013 at 01:58 PM
Ian.Dobinson
p.1 #17 · EOS Digital Solution Software available for download
Why is it a little odd. The software is not FREE to anyone . Its part of the package that comes with your camera . So unless you actually own a canon camera your not really entitled to use the software . And pretty much the easiest way to check you own a canon is to ask for its serial number
Just sayin
May 08, 2013 at 02:38 PM
AbramG
p.1 #18 · EOS Digital Solution Software available for download
That's a good point. Scratch my comment then.
May 08, 2013 at 04:49 PM
400d
p.1 #19 · EOS Digital Solution Software available for download
Problem?
http://bit.ly/10jqrgO
http://oi40./j6ssj5.jpg
May 08, 2013 at 07:07 PM
stanj
p.1 #20 · EOS Digital Solution Software available for download
Does it have any general purpose other than raw conversion of pictures and mocking with camera settings? God forbid someone could use the software to change picture style settings on their .... wait, only Canon cameras are supported anyway!
May 08, 2013 at 09:24 PM
