stanj Offline Dedicated FM Upload & Sell: On
p.1 #15 · How do you treat your "L" Glass | |
I don't see a problem with the camera being in (dry) grass. Mine has been there quite often over the past 20 years, and I can't think of a malfunction or even scratch as a result from it. I am more careful with mud and sand as well as water, but if one of your alternatives is to have two cameras hanging off your neck, I think the ground is a much better solution, esp. if it's grass like here. Two bodies banging against each other can't be good...
My lenses and esp. lens hoods have some signs of wear on them. That's because I use them in any weather, from my living room to climbing a mountain. I don't throw it against rocks, but I don't have them on display in a glass cage at home either.
- Stan
